[GRASS-user] Error while running v.db.addcol
Greetings
I0’m using winGRASS. When I run v.db.addcol in my WinXP I get this error:
Default driver / database set to:
driver: dbf
database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
0 [main] sh 5240 open_stackdumpfile: Dumping stack
trace to sh.exe.stackdump
0 [main] sh 5436 open_stackdumpfile: Dumping stack
c:/grass6/scripts/v.db.addcol: [: : integer expression
expected
0 [main] sh 2264 open_stackdumpfile: Dumping stack
0 [main] sh 3416 open_stackdumpfile: Dumping stack
ERROR: Column not found
But when I run in Win7 or other Win Machine (XP also) i do not get this error. Any explanation for this weird incident?
Thanks
Jenny
On Thu, Apr 14, 2011 at 6:13 PM, Jenny Turner <jennyturner1980@gmail.com> wrote:
Greetings
I0'm using winGRASS.
Please always indicate the version...
driver: dbf
expected
-> problem
  0 \[main\] sh 2264 open\_stackdumpfile: Dumping stack
ERROR: Column <cat> not found
Some fixes have been applied recently
http://trac.osgeo.org/grass/log/grass/branches/releasebranch_6_4/scripts/v.db.addcol
which are available now in GRASS 6.4.1.
If you can, please update to this bugfix release. But maybe others
have an idea, too.
