[GRASS-user] Error while starting GRASS6.4
Good Evening
I have just installed GRASS 6.4 in a Linux and I got this error while trying to start GRASS with WXPYTHON.
/usr/lib64/python2.4/site-packages/wx-2.8-gtk2-unicode/wx/_core.py:14448: UserWarning: wxPython/wxWidgets release number mismatch
warnings.warn(“wxPython/wxWidgets release number mismatch”)
Could anyone telm what this means? Is this a normal error?
Thanks
Luis
  warnings.warn("wxPython/wxWidgets release number mismatch")
I would interpret the error as indicating that wxPython ends up
loading a version of wxWidgets other than the one for which it was
built.
Either the wxPython installation is broken, or you have another
version of wxWidgets on the system which is taking precedence.
Luis Lisboa wrote:
Good Evening
Hmm, this is a warning, not an error. I got grass with wxGUI fully up and running on a system giving me this warning (Fedora 12 64bit). OK, I had to replace swig with a working version in order to get both wxnviz and wxdigitizer working, but the wxPython/wxWidgets release number mismatch warning itself had no effect on the functionality of the grass wxgui. With the standard swig version, the wxdigitizer was not working, but wxnviz and the wxgui worked.
Just keep going with the wxgui, it might work.
Markus M
