On 3/12/19 13:26, Veronica Andreo wrote:
Hi Moritz,
Thanks for your answer
In smaller subsets (per cutlines tiles), it works just fine.
With grass78 using python 3 ? Then probably it's not a python version issue.
What is the region size ? When it is calculating the raster statistics it uses r.univar with extended statistics (-e flag), if the region size is too big, actually you are right that this might lead to memory errors if it tries to run 4 instances in parallel.
Unfortunately, r.univar does not have a memory option allowing to limit memory usage. Maybe i.segment.stats should check the region size and available memory and bail out if there's not enough memory. Not sure how to calculate the needed memory size, though (especially since r.univar's -t flag is also set).
You could also try to reduce parallelization, i.e. run it with two processes only. It will obviously be slower.
Moritz
El mar., 3 dic. 2019 a las 12:41, Moritz Lennert (<mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>) escribió:
Hi Vero,
Le Mon, 2 Dec 2019 13:43:30 +0100,
Veronica Andreo <veroandreo@gmail.com <mailto:veroandreo@gmail.com>>
a écrit :
> Hi,
> We are trying to use i.segment.stats for a map with 800000+ segments
> and already in two different laptops, we get:
> bands=`g.list rast pat=IGUAZU_IMG_* sep=,`
RASTER_STATS=(min,max,range,mean,stddev,median,first_quart,third_quart,perc_90)
> AREA_STATS=(area,perimeter,compact_circle,compact_square,fd)
> i.segment.stats -rc \
> map=segments_full_region \
> rasters=$bands \
> raster_statistics=$RASTER_STATS \
> area_measures=$AREA_STATS \
> vectormap=segs_stats_map \
> processes=4
> Calculating geometry statistics...
> Calculating statistics for raster maps...
> Exception in thread Thread-3:
> Traceback (most recent call last):
> File "/usr/lib/python3.6/threading.py", line 916, in
> _bootstrap_inner self.run()
> File "/usr/lib/python3.6/threading.py", line 864, in run
> self._target(*self._args, **self._kwargs)
> File "/usr/lib/python3.6/multiprocessing/pool.py", line 463, in
> _handle_results
> task = get()
> File "/usr/lib/python3.6/multiprocessing/connection.py", line 251,
> in recv return _ForkingPickler.loads(buf.getbuffer())
> TypeError: __init__() missing 3 required positional arguments:
> 'module', 'code', and 'returncode'
> Does it have to do with memory? I used the module a month ago with
> 500000+ segments and it worked just fine...
I don't think memory is the issue, but I find the error message
pretty cryptic, so wouldn't exclude altogether. Could it be some
difference between Python 2 and 3 in the multiprocessing module ? Would
it be possible for you try running it in Python 2 ?
Maybe you could also try to run it on a smaller subset of the
segmentation result ?
Moritz
-- Département Géosciences, Environnement et Société Université Libre de
Bruxelles Bureau: S.DB.6.138
CP 130/03
Av. F.D. Roosevelt 50
1050 Bruxelles
Belgique
tél. + 32 2 650.68.12 / 68.11 (secr.)
fax + 32 2 650.68.30
