Hi there,
I'm using r.in.gdal to import Landsat7 images downloaded from USGS website. These landsat images are distributed in UTM-WGS84 for the specific zone. in this case I'm working with images from Brazil (WGS84 UTM ZONE 24S). So first I created an Location based on EPSG:32724.
Here goes the gdalinfo command for the image:
/Driver: GTiff/GeoTIFF
Files: L5216065_06520070405_B10.TIF
Size is 8171, 6991
Coordinate System is:
PROJCS["WGS 84 / UTM zone 24N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-39],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32624"]]
Origin = (443999.999999999941792,-694500.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)/
As can be seen it's North instead of South. Nevertheless, r.in.gdal imports it and it even says: Projection of input dataset and current location appear to match
But when I try to display I get an error window stating:
Execution failed: 'd.rast -o map=import@PERMANENT --q'
Details:
Error: Unable to open raster map <import@PERMANENT>
And nothing else is stated
Shall I add this issue to the Error/debug trac list? Or how can I fix this?
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5258 (20100707) __________
The message was checked by ESET NOD32 Antivirus.
