Greetings and happy new year
I want to create a vector file similar to another one that exists. To test this I decided to use bridges@PERMANENT .
After I do “DISPLAY MAP” in map display I select “Digitize” from Map Display toolbar. Then, wxDigitizer toolbar appears.
(so far, so good)
Then, I select New Vectorfile. A menu asking for output file name appears and I enter new_input and after I press OK an ERROR WINDOW appears stating:
Unable to initialize display driver of vector digitizer. see ‘Command output’ for details.
Details: ‘Non type’ object has no attribute ‘Open Map’ ( ).
At command output window the following text appears:
New vector map new_input@PERMANENT created
File "/usr/local/grass-6.4.0svn/etc/wxpython/gui_modules/v
digit.py" line 233, in init
mapwindow)
File "/usr/local/grass-6.4.0svn/etc/wxpython/vdigit/grass6
_wxdigit.py", line 334, in init
this = _grass6_wxdigit.new_Digit(*args)
TypeError: in method ‘new_Digit’, argument 2 of type
‘wxWindow’
Ok, could anyone explain me what is wrong and what can I do to fix it/solve it?
Thank you
Best wishes,
Franz
