I would like to integrate my commands in a Python script. I use Eclipse for development. Everything works fine in the GUI, but the same command, pasted to the command line, produces this:
import os
import grass.script as grass
env = grass.gisenv()
print env
r = grass.read_command("g.list", type='vect')
print r
# Ask user for his name and stores
input1 = 'uhe'
#Create a category to name each line
grass.run_command ("v.category", input=input1, output='category', layer='2', type='boundary', option='add')
Response : ATTENTION : La couche vectorielle <category> existe déjà et va être écrasé
ATTENTION : Table <category> linked to vector map <category> does not exist
DBMI-DBF driver error:
ATTENTION : Impossible d'ouvrir la base de données <Cat
D:/work/grassdata/data/test_chaudanne/uhe2/dbf/> avec le driver
<dbf>
ATTENTION : Unable open database <Cat
D:/work/grassdata/data/test_chaudanne/uhe2/dbf/> by driver
<dbf>
ATTENTION : Impossible de trouver la table <Table> liée à la couche
ATTENTION : Impossible de supprimer la couche vectorielle <category>
I have tried to use v.db.connect but it makes me the same error's message.
Thank's for any hints.
Yvan
