Hi to all!
I am building a livecd for the Foss4g2006 and grass 6.1 is intside it.
If i try to open a raster or a vector from the dm, I got this error:
couldn’t execute “g.mapsets”: no such file or directory
while executing
“exec g.mapsets -p”
(procedure “GSelect_::create” line 33)
invoked from within
“GSelect_::create $element”
(procedure “GSelect” line 3)
invoked from within
“GSelect cell”
Opening the layer via shell is working fine…
This command it’s not available in 6.1 neither from shell ( i got 6.0.2 on the same livecd and g.mapsets is working fine)
Anyone got an idea of this error?
Thanks
Luca
Luca Casagrande wrote:
Hi to all!
couldn't execute "g.mapsets": no such file or directory
while executing
"exec g.mapsets -p"
(procedure "GSelect_::create" line 33)
invoked from within
"GSelect_::create $element"
(procedure "GSelect" line 3)
invoked from within
"GSelect cell"
Opening the layer via shell is working fine...
This command it's not available in 6.1 neither from shell ( i got 6.0.2 on
If you compiled from source, you need to determine why g.mapsets
failed to compile.
If you are using a binary package, you need to notify the creator of
the binary package, identifying exactly which package you are
referring to.
