[GRASS-user] Error with GRASS 7.8.3
Hi all:
I have had these 2 problems for a while, but tried to work around them… It may be with my build from source…
PROBLEM #1
When I try to create a new LOCATION and MAPSET (just a simple lat-long LOCATION over the CONUS), I use the GUI to select the projection and datum (lat-long & WGS84)… I get something like this:
Starting GRASS GIS…
File “/usr/local/grass78/gui/wxpython/location_wizard/wizard.py”, line 1080, in OnPageChanging
self.parent.parent, transforms=ret)
File “/usr/local/grass78/gui/wxpython/location_wizard/dialogs.py”, line 617, in init
transforms = ‘—\n\n0\nDo not apply any datum transformations\n\n’ + transforms
TypeError: must be str, not bytes
Exit was requested in GUI.
GRASS GIS will not start. Bye.
PROBLEM #2
when I attempt to re-project a RASTER between LOCATIONS, I get no errors, but all the raster values are NULL, even with the target LOCATION defined large enough. And sometimes, it works!
r.proj will report something like this:
Output:
Cols: 1 (original: 5390)
Rows: 1 (original: 3288)
North: 4762.500000 (original: 1985962.500000)
South: 0.000000 (original: -13673137.500000)
West: -4762.500000 (original: -11820525.000000)
East: 0.000000 (original: 13849350.000000)
EW-res: 4762.500000
NS-res: 4762.500000
The original raster is perfectly fine. Any initial thoughts?
Best,
Tom
Hi Markus!
OMG; thank you!!! version 7.8.4 solved my issues… I thought I was going crazy (I was)… I should have reported my problems sooner… thank you everyone!
Best,
Tom
Thomas E Adams, III
1724 Sage Lane
Blacksburg, VA 24060
tea3rd@gmail.com (personal)
tea@terrapredictions.org (work)
1 (513) 739-9512 (cell)
