[GRASS-user] ERROR with v.report
The following command gives me an error:
v.report map=rivers option=length units=meters
OUTPUT:
Displaying column types/names for database connection of layer 1:
File di input specificato due volte (english: input file was set twice)
ERROR: There is a table connected to input vector map ‘fiumi_princ@PERMANENT’, but there are no categories present in the key column ‘cat’. Consider using v.to.db to correct this.
The vector layer has 227 lines and 12 categories, correctly connected to the db.
I’ve also tried to update a table column and it works fine:
v.to.db map=rivers option=length units=meters columns=len
Working with GRASS 6.4RC1 from OSGeo4W on a Winows 7 machine.
giovanni
I’ve just found that it’s a known bug: http://trac.osgeo.org/grass/ticket/1139
2011/11/21 G. Allegri <giohappy@gmail.com>
OUTPUT:
giovanni
On Mon, Nov 21, 2011 at 6:28 PM, G. Allegri <giohappy@gmail.com> wrote:
I've just found that it's a known bug:
Could you add " -x" to the first line of the script?
Then run again and it should output shell debugging to
better understand what's ongoing there.
OUTPUT:
'fiumi_princ@PERMANENT', but there are no categories present in the key
column 'cat'. Consider using v.to.db to correct this.
the db.
I've also tried to update a table column and it works fine:
giovanni
grass-user mailing list
grass-user@lists.osgeo.org
