Hi, everybody!
I receive an error If I try to delete a map “[tmrast@erdbeben@erdbeben] is a base map. Remove reclassed map first: MASK@erdbeben”. But the MASK is already deleted, I haven’t any MASK-maps… How can solve this problem?
Thanks.
Hi, everybody!
Thanks.
On Wed, Feb 9, 2011 at 11:19 AM, Sofina Natalia <nsofina@gmx.de> wrote:
Hi, everybody!
I receive an error If I try to delete a map "[tmrast@erdbeben@erdbeben] is a
base map. Remove reclassed map first: MASK@erdbeben". But the MASK is
already deleted, I haven't any MASK-maps... How can solve this problem?
I rarely run into the same (unexplained) problem.
If you use instead g.mremove on that map, it will work.
