[GRASS-user] error
Hi everybody!
Some time ago I installed a new version of GRASS (GRASS 6.4.1 (2011) for Windows. And now I can’t start some modules that I created by myself. I get the following error:
Ungültiger Name der Vektorkarte <>. Darf nicht ‘.’ oder ‘NULL’ enthalten.
ERROR: Name der Ausgabe-Vektorkarte <> ist keine gültiger Kartenname.
I guess, this version of GRASS doesn’t understand the definition of temporary files (for example, $TMPVECT)
Begin of the script
#g.message “Remove temporary files”
g.remove vect=tmp_points
g.remove vect=tmp
points_txt=“C:/Work_directory/Algorithm/China/points.txt”
echo $GIS_OPT_INPUT1
echo $GIS_OPT_OUTPUT1
cats=v.db.select map=$GIS_OPT_INPUT1 columns=cat | sed "s/cat//g"
echo “cats =” $cats
echo “# Object Number DPC value” > $GIS_OPT_OUTPUT1
for i in $cats
do
echo “i =” $i
if [ $i -lt 14 ] ;
then
continue
fi
v.extract input=$GIS_OPT_INPUT1 output=$TMPVECT list=$i
v.to.points -v -i input=$TMPVECT output=$POINTS type=boundary,area dmax=5
v.out.ascii input=$POINTS output=$points_txt
I like the new GRASS version and try to adjust it to my needs.
Perhaps anybody has had to face the same problem or knows a solution?
Thanks.
On Mon, May 2, 2011 at 3:25 PM, nsofina <nsofina@gmx.de> wrote:
Hi everybody!
Ungültiger Name der Vektorkarte <>. Darf nicht '.' oder 'NULL' enthalten.
[I see the grammatical error in the message which will be fixed for 6.4.2]
I guess, this version of GRASS doesn't understand the definition of
How did you define $TMPVECT? The rules are this:
The naming convention for vector maps requires that map names start
with a character, not
a number (map name scheme: [A-Za-z][A-Za-z0-9_]*) - see also
http://grass.osgeo.org/grass64/manuals/html64_user/vectorintro.html
hope this helps,
