Just updated from cvs. Got an error with r.neighbors (below) and now
gis.m complains that <map> is not valid, so I can't have zoom to map,
etc.
cheers
Carlos
guano@eclipse:~/tmp_install/gis/grass6/raster/r.neighbors$ make
gcc -I/home/guano/tmp_install/gis/grass6/dist.i686-pc-linux-gnu/include
-march=prescott -O2 -pipe -fomit-frame-pointer -Wall
-D_FILE_OFFSET_BITS=64 -DPACKAGE=\""grassmods"\"
-I/home/guano/tmp_install/gis/grass6/dist.i686-pc-linux-gnu/include \
-o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function 'main':
main.c:132: error: expected expression before '<<' token
main.c:135: error: expected expression before '==' token
main.c:138: error: expected expression before '>>' token
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
Carlos Henrique Grohmann - Guano
Visiting Researcher at Kingston University London - UK
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can't stop the signal.
etc.
cheers
Carlos
You got a conflict during update; the output from "cvs update" will
have:
cvs update: conflicts found in driver.c
C raster/r.neighbors/main.c
This occurs if the file has been locally modified in a way which
conflicts with changes to the CVS version, such that the two sets of
changes cannot be merged automatically.
If you want to keep your local changes, you will need to edit the
portion of the file between the <<<<<<< and >>>>>>>, resolving the
different versions. Otherwise, just delete main.c and update again.
Indeed I made some changes to r.neighbors, to allow bigger windows, as
the limit of 25 was to little for me (I needed 101!)
thanks
Carlos
BTW, what do you guys think about this limit of 25x25?
> etc.
> cheers
> Carlos
have:
_________________
The options list for size= was used as a simple way to restrict the
size to an odd number. At the time, 25x25 would probably have been
impractically slow on contemporary hardware, so the limitation
wouldn't have been an issue.
You aren't the first person to run into this. The options list should
probably be removed in favour of a coded check.
