[GRASS-user] errors in r.drain (develbranch)
Hello all,
after a full SVN of develbranch, I'm getting errors in r.drain:
Errors in:
/home/guano/pessoal/tmp_install/gis/grass6_devel/raster/r.drain
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mon Apr 6 14:10:58 BRT 2009
make: *** [default] Error 1
guano[grass6_devel]$ cd raster/r.drain/
guano[r.drain]$ make
gcc -I/home/guano/pessoal/tmp_install/gis/grass6_devel/dist.i686-pc-linux-gnu/include
-mt
une=nocona -minline-all-stringops -O2 -Wall -D_FILE_OFFSET_BITS=64
-I/usr/include/gdal
   -DPACKAGE=\""grassmods"\"
-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:174: warning: format not a string literal and no format arguments
main.c:178: warning: format not a string literal and no format arguments
main.c:183: warning: format not a string literal and no format arguments
main.c:204: warning: format not a string literal and no format arguments
main.c:228: warning: format not a string literal and no format arguments
main.c:242: warning: the address of ‘vect’ will always evaluate as ‘true’
main.c:251: warning: format not a string literal and no format arguments
main.c:270: warning: format not a string literal and no format arguments
main.c:291: warning: format not a string literal and no format arguments
main.c:311: warning: format not a string literal and no format arguments
main.c:323: warning: format not a string literal and no format arguments
main.c:398: warning: format not a string literal and no format arguments
main.c:103: warning: unused variable ‘vect_mapset’
main.c:379: warning: ignoring return value of ‘write’, declared with
attribute warn_unused
_result
main.c:391: warning: ignoring return value of ‘write’, declared with
_result
main.c:497: warning: ignoring return value of ‘read’, declared with
attribute warn_unused_
result
main.c: In function ‘drain’:
main.c:611: warning: ignoring return value of ‘read’, declared with
result
main.c: In function ‘drain_cost’:
main.c:664: warning: unused variable ‘col’
main.c:664: warning: unused variable ‘row’
main.c:681: warning: ignoring return value of ‘read’, declared with
result
main.c:73: warning: ‘dir_mapset’ may be used uninitialized in this function
main.c:84: warning: ‘dir_buf’ may be used uninitialized in this function
main.c:74: warning: ‘tempfile3’ may be used uninitialized in this function
main.c:66: warning: ‘dir_fd’ may be used uninitialized in this function
In function ‘open’,
    inlined from ‘main’ at main.c:387:
/usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’
declared with attribut
e error: open with O_CREAT in second argument needs 3 arguments
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
guano[r.drain]$
any hints appreciated :slight_smile:
Carlos
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
carlos dot grohmann at gmail dot com
http://www.igc.usp.br/pessoais/guano/
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can’t stop the signal.
2009/4/6 Carlos "Guâno" Grohmann <carlos.grohmann@gmail.com>:
Hello all,
Errors in:
(that's indeed grass7_devel/raster/r.drain/, right?)
-mt
-I/usr/include/gdal
that line reads
                G_warning(_("Starting point %d is outside the current region"),
in GRASS 7.
I assume that you lost somehow --with-nls as configure parameter so that
the gettext macro isn't recognised completely.
I suggest a "make distclean" and new configure.
Errors in:
It's develbranch 6 (GRASS 6.5)
svn checkout https://svn.osgeo.org/grass/grass/branches/develbranch_6
grass6_devel
-mt
-I/usr/include/gdal
that line reads
in GRASS 7.
--with-nls is there (from ./configure):
checking whether to use NLS... yes
checking for gettext... yes
This is a fresh download..
Carlos
_________________
This might be an error with my updates
(http://trac.osgeo.org/grass/changeset/36351). I'm not sure why there
wasn't any error reported for me or others, but I see that there is an
inconsistency in the code (my addition at 387 compared to lines 373
and 374).
387 dir_fd = open(tempfile3, O_RDWR | O_CREAT);
Should be:
387 dir_fd = open(tempfile3, O_RDWR | O_CREAT, 0666);
Trying making that change and recompile. Markus, I can submit a diff
for this line if needed.
-Colin
Errors in:
grass6_devel
-mt
-I/usr/include/gdal
that line reads
in GRASS 7.
Carlos
_________________
grass-user mailing list
grass-user@lists.osgeo.org
Yes, that fixed it.
many thanks
Carlos
2009/4/6 Colin Nielsen <colin.nielsen@gmail.com>:
and 374).
Should be:
-Colin
Errors in:
grass6_devel
-mt
-I/usr/include/gdal
that line reads
in GRASS 7.
Carlos
_________________
_________________
2009/4/7 Colin Nielsen <colin.nielsen@gmail.com>:
ah, so it was on develbranch_6/ - I didn't catch that.
and 374).
Should be:
Fix in SVN now.
BTW: I see that your changes didn't make it into GRASS 7 - intentionally?
I don't think that it is a good idea to leave GRASS 7 behind - the longer
we wait with forward-porting the more difficult it becomes.
Just my 0.02 cent
