[GRASS-user] Errors running r.inund.fluv
I have output errors from running r.inund.fluv using GRASS 6.4.3. on Ubuntu 13.10 none of my output maps were written successfully; my DEM is coarse (30m). But below is what I am getting in term window output – much more detail in the Command Window output, which I can provide.
Tom
GRASS 6.4.3 (potomac_utm):~/grass/data > r.inund.fluv
GRASS_INFO_WARNING(25914,1): Table <limiti_alveo> not found in database </home/teaiii/grass/data/potomac_utm/teaiii/sqlite/sqlite.db> using driver
GRASS_INFO_END(25914,1)
GRASS_INFO_ERROR(25916,1): Unable to describe table <limiti_alveo>
GRASS_INFO_END(25916,1)
(python:20172): Pango-CRITICAL **: pango_layout_get_cursor_pos: assertion ‘index >= 0 && index <= layout->length’ failed
GRASS_INFO_WARNING(28290,1): Table <limiti_alveo> not found in database </home/teaiii/grass/data/potomac_utm/teaiii/sqlite/sqlite.db> using driver
GRASS_INFO_END(28290,1)
GRASS_INFO_ERROR(28292,1): Unable to describe table <limiti_alveo>
GRASS_INFO_END(28292,1)
(30m). But below is what I am getting in term window output -- much more
Tom
<sqlite>
Some part of the Addon is written in Fortran, did you compile all of
those binaries?
Requires gfortran or the like to be present on the system at compile time.
To check, run this in a GRASS 6.4 session:
ls $GISBASE/etc/fortran_code/
It should list:
2d_path* clean_inundation* correction_from_path* dati.mod* dd.mod*
find_main_channel*
Some of those probably create the table which isn't found in your sqlite.db.
Marcus,
Yes; when I run ls $GISBASE/etc/fortran_code/ I get all of those:
2d_path* clean_inundation* correction_from_path* dati.mod* dd.mod* find_main_channel*
So, do you think I should build 6.4.svn and should probably use this?
Tom
Tom
those binaries?
It should list:
find_main_channel*
Some of those probably create the table which isn’t found in your sqlite.db.
Thomas E Adams, III
718 McBurney Drive
Lebanon, OH 45036
1 (513) 739-9512 (cell)
On Sat, Apr 19, 2014 at 12:06 AM, Thomas Adams <tea3rd@gmail.com> wrote:
Marcus,
find_main_channel*
ok, so the installation seems to be complete.
Well, that was only meant to test the updated g.extension.py.
Re: r.inund.fluv it may be the best to contact the authors since it is an addon.
Best
