[GRASS-user] Errors with v.in.ascii with Strings
I am able to import a CSV file containing two columns both of double
precision, but once I add in a third column (called 'name') of text with
arbitrary length, I get the following error:
"x column is not of number type"
The command I am using is as follows:
v.in.ascii input=data.csv output=incidents format=point fs=, skip=1
{columns=x double precision, y double precision, name varchar(255)} x=1 y=2
z=0 cat=0 --overwrite
There must be something in the text that v.in.ascii does not like. FWIW,
this third column contains street addresses. What could be causing this?
R.
View this message in context: http://www.nabble.com/Errors-with-v.in.ascii-with-Strings-tp19486076p19486076.html
x=1 y=2 z=0 cat=0 --overwrite
maybe a comma in the street address is confusing it? Can you export with
another field separator like "|"?
or turn on full debug messages:
  g.gisenv set="DEBUG=5"
and rerun. Set it back to 0 to get no messages.
no header lines or blank lines at the end?
Hamish
The debug option helped quite a bit.
Solved:
This may be a bug, or something that could/should be improved (maybe it
already has been...I'm using 6.3RC6). There were missing values in the x and
y columns because there were some addresses that could not be geocoded and
grass did not know what to do when it encountered a blank cell. Ignoring the
row, and displaying a warning to the user with the row number may be better
IMO.
Thanks again!
Ryan
View this message in context: http://www.nabble.com/Errors-with-v.in.ascii-with-Strings-tp19486076p19487278.html
On Mon, Sep 15, 2008 at 6:55 AM, Ryan R. Rosario <uclamathguy@gmail.com> wrote:
Solved:
IMO.
In r.in.xyz I had implemented exactly this (in my case, to avoid that
super long
Lidar files were refused due to a broken last line which only
contained a strange
symbol):
-i Ignore broken lines
They are printed as warning, though, so that the user knows what's going on.
Maybe we want this in v.in.ascii, too.
