I've set up a location (GRASS 6.4.2. RC1487 15M (2011)), using the Location
wizard, by selecting the coordinate system parameters as so:
projection: UTM
datum with ellipsoid: projection zone 30N
datum code: eur50 (European datum 1950)
when I run g.region -p I get the following:
projection: 1 (UTM)
zone: 30
datum: ** unknown (default: WGS84) **
ellipsoid: international
Is it a problem that the datum has not been saved as European datum 1950?
The reason I'm asking is that when I pull a vector map from this location
into a location with the following projection parameters
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
I get slightly different re-projected coordinates than a colleague who does
the same process in ArcGIS. I would like to confirm that the UTM location is
set up correctly.
Many thanks for your help,
Sophie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/European-Datum-1950-is-not-saved-in-the-region-information-tp6958890p6958890.html
