> this command gives error
> d.vect map=jeo2 fcolor=green where="label~'CAMURTASI' and label !~ 'KUMTASI'" type=area
> bash: !~: event not found
> But it works in psql side
> what is the alternative of "!~" in grass ?
"" quoting does not stop bash from expanding $VAR and ! events.
Usually you would use '!' for that, but in this case ....
try
where="label~'CAMURTASI' and label "'!'"~ 'KUMTASI'"
? but there's probably a better way..
If you don't use history expansion, "set +H" turns it off.
