[GRASS-user] execute commands automatically after start of grass
Hi
I am using grass in combination with R, wherefore I have to start R
(or emacs) after starting grass.
Is there any way, to make this automatic, i.e., can I specify a script
which is executed inside grass after it is started?
In addition, I only would like that to happen when I start grass in a
certain mapset and not in other mapsets.
Thanks
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Plant Conservation Unit
Department of Botany
University of Cape Town
Rondebosch 7701
South Africa
hi,
you can adjust anything in .grass.bashrc file
e.g.
#!/bin/sh
export GRASS_ADDON_PATH=$HOME/usr/grass/
export GRASS_PAGER=/bin/more
jachym
[1] http://grass.osgeo.org/grass64/manuals/html64_user/variables.html
2008/8/1 Rainer M Krug <r.m.krug@gmail.com>:
Hi
Thanks
Rainer
Rondebosch 7701
South Africa
grass-user mailing list
grass-user@lists.osgeo.org
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
On Fri, Aug 1, 2008 at 11:16 AM, Jachym Cepicky
<jachym.cepicky@gmail.com> wrote:
hi,
e.g.
#!/bin/sh
Thanks - that looks exactly what I am looking for.
But is there a way of specifying a certain .grass.bashrc which should be used?
The reasoning is that for certain projects I need R and emacs and
would like to start them automatically, for others not. Obviously, I
could use a startup script which renames the apropriate file to
.grass.bashrc, but it would be cleaner to be able to specify it when
starting grass.
jachym
Hi
Thanks
Rainer
Rondebosch 7701
South Africa
Jachym Cepicky
Centre of Excellence for Invasion Biology
Faculty of Science
Natural Sciences Building
Private Bag X1
University of Stellenbosch
Matieland 7602
South Africa
Why not put a test inside .grass.bashrc to check if you are in the
mapset you want R to run?
Something like:
<pseudo-code here - can't remember bash sintax>
if [ $MAPSET = __your_targuet__ ]; do
   r &
  emacs &
fi
Daniel
hi,
e.g.
#!/bin/sh
starting grass.
jachym
Hi
Thanks
Rainer
Rondebosch 7701
South Africa
Jachym Cepicky
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
On Fri, Aug 1, 2008 at 2:35 PM, Daniel Victoria
Something like:
  r &
emacs &
fi
Good idea - I think I will go that way.
Rainer
Daniel
hi,
e.g.
#!/bin/sh
starting grass.
jachym
Hi
Thanks
Rainer
Rondebosch 7701
South Africa
Jachym Cepicky
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
Faculty of Science
Private Bag X1
Matieland 7602
South Africa
