i have a very simple question but i'm not able find the simple answer.
I'm following the procedure for Setting the GRASS environmental
variables, <http://grasswiki.osgeo.org/wiki/GRASS_and_Shell>in the bash
environment.
Everything works grate and I'm able to access to all grass commands.
My question is how I can exit from grass and return to the
bash-with-nograss.
You cannot "exit" GRASS as it is not an application by itself. If you do not want to have access to the GRASS modules anymore, just unset your environment variables.
If you want to change your prompt, set PS1 to something else.
environment.
bash-with-nograss.
On Thu, Feb 19, 2015 at 7:11 PM, Nikos Alexandris <nik@nikosalexandris.net>
> environment.
> bash-with-nograss.
Alternatively, you could just spawn a separate shell (with "bash")
before setting any of the GRASS environment variables then terminate
it (with "exit") when you're finished.
A child process (normally) inherits its environment from its parent at
start-up, but any changes to the child's environment won't affect the
parent's.
