[GRASS-user] exponentiation with v.db.update
I'm trying to populate a column with 10 raised to the power of the
values in another column:
v.db.update map=ItaReg column=x qcolumn=10^logx
but I get a dbmi protocol error. I've tried using either single or
double quotes with no success. If I use a combination of both, i.e.
"qcolumn= ' 10^logx ' " it doesn't report any error, but doesn't do
the operation either (the column remains unchanged).
It works fine for other operations (e.g. 10*logx), though. Is there
another way in which I should specify the exponentiation?
Marcia
Which database back-end are you using? I seem to recall that the DBF
back-end only supports a very limited subset of update operations.
cheers,
Dylan
On Tue, Jun 9, 2009 at 8:56 AM, A. Marcia
BARBOSA<anamarciabarbosa@gmail.com> wrote:
Marcia
grass-user mailing list
grass-user@lists.osgeo.org
On 09/06/09 17:56, A. Marcia BARBOSA wrote:
Which db backend are you using ?
This works for me with a PostgreSQL database:
v.db.addcol ssbel_pg col="test double precision"
v.db.update ssbel_pg col=test value="cat^2" (or qcol="cat^2")
In PostgreSQL there is also power(a,b).
For SQLite the same function is available in the extension-functions.c available here:
http://sqlite.org/contrib/download/
Moritz
Yeah I'm doing it on a dbf attribute table. It doesn't work with the
quotes, nor with power(10,x) - error message always.
Does anyone know how to do an exponentiation update on a dbf table? Or
do I really have to do the update outside GRASS and then re-connect
the table?
Márcia
the table?
why not using sqlite backend? dbf is very limited for any serious use.
It may seem quite simple for some, but to me all these things are a
complete mystery... I'm actually very surprised I became able to
handle GRASS! I'm planning on switching all my databases to PostgreSQL
within this year (after taking a course, of course), but right now I
have to work with what I've got... dbf it is. I've just managed to
calculate the column outside and re-connect it to the vector map.
Grazie,
Márcia
Well, when you get a chance, here are some tips on converting DB back-ends:
http://casoilresource.lawr.ucdavis.edu/drupal/node/733
Note that there is a lot of red text on that page. It means "be careful!".
Dylan
Dylan Beaudette
Soil Resource Laboratory
University of California at Davis
530.754.7341
It is not so bad:
http://grass.itc.it/grass64/manuals/html64_user/databaseintro.html
To migrate a GRASS database table (or a GRASS vector map) to a different
DBMI engine, the best solution is to create a new MAPSET, define the
DBMI settings accordingly with db.connect and if needed, db.login. Then
the table of interest can be copied over with db.copy from the original
MAPSET. Likewise, a vector map including its table(s) are copied from
the original MAPSET to the current MAPSET with g.copy.
PostgreSQL might be overkill for personal use.
All the best.
the table?
SQL for dbf is very limited [1,2], so you would have to either do it outside GRASS, or switch to a more sophisticated SQL backend.
Moritz
[1]http://grass.osgeo.org/grass64/manuals/html64_user/sql.html
[2]http://grass.osgeo.org/grass64/manuals/html64_user/grass-dbf.html
