GRASS GIS development is currently driven by a relatively
small number of people, some of them working on GRASS only
in their spare time. And most of them have their focus on
areas other than map production GUIs.
So your best bet to get new functionality into the system
that you/someone you know needs is to raise
some funding and hire a programmer to do the job.
There seems to be almost unlimited money floating around for
renting ridiculously expensive proprietary licenses, so
surely, there must be some to invest into open source GIS
development?
Alternatively, there are many more open source GIS apps
that can be used (in combination with GRASS) to cover any
functionality gaps. E.g. Quantum GIS, OpenJUMP and gvSIG
all have easy-to-use map printing facilities.
Quantum GIS already has a GRASS interface and the same is
currently in the works for gvSIG (via the SEXTANTE tools).
Best,
Ben
----- Original Message -----
To: "Hamish" <hamish_b@yahoo.com>
Cc: grass-user@lists.osgeo.org
Sent: Wednesday, May 26, 2010 11:50:16 AM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
Subject: [GRASS-user] export as eps/svg ind grass64rc6 - grass7 ??
sorry if I came back on this topic a bit late with respect to the
messages below, but I think it's a quite crucial one and like to know if
users/developers share similar needs.
I have just had to struggle with a arc* user for printing an map and to
try to convince him/her to switch to GRASS....
I also recall some "dilemma" provocative messages in 2008 like:
I come here with a question/dilemma...
Why ps.map lacks so much user support?
A lot of people know about GRASS all over the world, but nearly nobody
use it, since nearly any software in the world is less difficult to
produce maps.
GRASS is a wonderful tool for analysis, but it fails to produce the
ultimate result: a map.
The point is how one can produce an output map which contains at least:
1. a raster map
2. some vector with labels
3. scale
One should be able to decide about:
1. map scale,
2. paper format,
3. file format
I think that at the present development level, the user should be able
to make such a map from the GUI. The output map vector elements should
also be editable in skencil, inkscape, openoffice, etc.. with the raster
as a base (e.g. a dem or a raster topography)
I am aware that the present-day wxpython map display allows to produce
bitmaps (.png, .tif, etc..) and that the things in the list above can be
drawn off ps.map - ps.output. However at present one has to load all the
info into a "mapping instructions file" which has to be changed each
time one wants to map a different map. In the oldtcltk this issue was
overcome by the possibility to create the .txt script file directly from
the tcltk display window.
I wonder if it is planned to create a sort of printing layout which can
allow the user to easily output "a map".
many thanks in advance
Francesco
Hamish wrote:
Achim wrote:
I know that it is not possible in grass65,
no my friend, it is available: d.out.file
format Graphics file format
options: png,ppm,tif,geotiff,jpg,bmp,ps,eps,svg,pdf
And of course v.out.svg.
See d.mon for details on the Cairo and PS (PostScript) drivers
which are another way to go.
and of course ps.map or ps.output PostScipt [-> PDF] -> Inkscape is
great if you need print quality output.
but can one export the graphics display to svg or eps in grass7
(from gui-display)?
there is a save-as pull down menu in the map display. I can't remember
what's on it except that GeoTiff is on the planned feature list.
Alternatively I would like to load my workspace settings to
a xmon in order to export from there. Is that possible?
(I really dont want to rebuild the layer settings from the
shell again
GRASS 7 doesn't have xmons, but the PS and Cairo drivers there are
much better than in GRASS 6. (mostly the xmons hold them back in grass 6)
good luck,
Hamish
grass-user mailing list
____________________________________________
Francesco Mirabella,
Geologia Strutturale e Geofisica
Universita' di Perugia,
Dipartimento di Scienze della Terra,
Piazza Universita' 1, 06100 Perugia (Italy)
tel: ++39.(0)75.584.7948
fax: ++39.(0)75.585.2603
skype: francesco.mirabella
web: http://www.unipg.it/~mirabell/
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
