Hi
I would like to export a 3D line feature into a csv format, as in:
x y z
1 2 3
I am not interested in the attribute tab;e, as I need the coordinates incl z.
Is this possible? I only managed to export the attribute table so far (which I do not need…)
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
On Fri, 2011-07-08 at 11:19 +0200, Rainer M Krug wrote:
Hi
x y z
1 2 3
FIrst create attrib columns for the X-Y-Z values:
v.db.addcol col=“x double precision, y double precision z double predision”
Then put the values into those columns
v.to.db option=coor column=“x,y,z”
Now export the attrib table as you did before.
Rainer
South Africa
Skype: RMkrug
This mail was received via Mail-SeCure System.
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Hi
x y z
1 2 3
Hi Micha,
This does unfortunately not work, as I have a line feature and not a point feature - and I would like to extract the co-ordinates of all vertexes of each line. I need this data, as I have to do some analysis afterwards for which I need the z-co-ordinate of each vertex. I could convert the lines to points, but how do I know which ones belong to which line and in which order?
Rainer
Rainer
South Africa
Skype: RMkrug
South Africa
Skype: RMkrug
<mailto:micha@arava.co.il>> wrote:
__
Hi
x y z
1 2 3
coordinates incl z.
Hi Micha,
v.db.addcol <vectormap> col="x double precision, y double precision
z double predision"
v.to.db <vectormap> option=coor column="x,y,z"
v.to.db option=start / option=end will give you the beginning and end coordinates of line beginnings and ends. AFAIK, this will not include each vertex of a line, only nodes.
Or you can use v.build option=dump, although the result will need some treatment to be usable.
Moritz
