[GRASS-user] Export coordinates of 3D line feature into csv format?
Rainer M Krug wrote:
I would like to export a 3D line feature into a csv format, as
in:
x y z
1 2 3...
I am not interested in the attribute tab;e, as I need the
coordinates incl z.
http://grass.osgeo.org/wiki/Addons#v.out.ascii.mat
Hamish
in:
x y z
1 2 3…
coordinates incl z.
Thanks - this (and v.out.ascii.db) looks exactly like what I am looking for - but I have problems installing it.
I use Ubuntu Natty, and have grass 6.4.1 (grass and grass-dev) installed from the repository (ubuntugis-unstable), but it seems that I do not have everything I neet - the complete tool (/usr/lib/grass64/tools/) directory is missing, and I get the output below. In addition: I also get the error ERROR: G_getenv(): Variable LOCATION_NAME not set.
Do I need to install grass from source to be able to use g.extension under ubuntu?
Rainer
GRASS 6.4.1 (grass):~/Documents/Projects/AlienSpread > g.extension extension=v.out.ascii.mat prefix=~/lib/grass64
Fetching <v.out.ascii.mat> from GRASS-Addons SVN (be patient)…
A v.out.ascii.mat/v.out.ascii.mat
A v.out.ascii.mat/Makefile
Checked out revision 47092.
Compiling <v.out.ascii.mat>…
if [ ! -d /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts ]; then mkdir -p /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts; fi
/usr/bin/install -c v.out.ascii.mat /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts/v.out.ascii.mat
make htmlscript scriptstrings
make[1]: Entering directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat' make /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/docs/html/v.out.ascii.mat.html HTMLSRC=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts/v.out.ascii.mat make[2]: Entering directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat’
if [ “/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts/v.out.ascii.mat” != “” ] ; then GISRC=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu PATH=“/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/bin:$PATH” LD_LIBRARY_PATH=“/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/bin:/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/lib:/usr/lib/grass64/lib:/usr/local/lib” LC_ALL=C fakeroot /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts/v.out.ascii.mat --html-description < /dev/null | grep -v ‘|’ > v.out.ascii.mat.tmp.html ; true ; fi
/usr/lib/grass64/tools/mkhtml.sh v.out.ascii.mat ; mkdir -p /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 v.out.ascii.mat.tmp.html /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/docs/html/v.out.ascii.mat.html ; for file in *.png *.jpg ; do head -n 1 $file | grep ‘^#!’ > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true
/bin/sh: /usr/lib/grass64/tools/mkhtml.sh: not found
make[2]: Leaving directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat' GISRC=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/demolocation/.grassrc64 GISBASE=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu PATH=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/bin:$PATH LD_LIBRARY_PATH="/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/lib:/usr/lib/grass64/lib:/usr/local/lib" g.parser -t v.out.ascii.mat | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' > /usr/lib/grass64/locale/scriptstrings/v.out.ascii.mat_to_translate.c ; true /bin/sh: cannot create /usr/lib/grass64/locale/scriptstrings/v.out.ascii.mat_to_translate.c: Directory nonexistent ERROR: G_getenv(): Variable LOCATION_NAME not set make[1]: Leaving directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat’
make mancmd
make[1]: Entering directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat' make /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/man/man1/v.out.ascii.mat.1 MANSRC=/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/docs/html/v.out.ascii.mat.html make[2]: Entering directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat’
mkdir -p /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.1 sh /build/buildd/grass-6.4.1/tools/g.html2man/g.html2man /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/docs/html/v.out.ascii.mat.html /build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/man/man1/v.out.ascii.mat.1 1
sh: Can’t open /build/buildd/grass-6.4.1/tools/g.html2man/g.html2man
make[2]: *** [/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/man/man1/v.out.ascii.mat.1] Error 127
make[2]: Leaving directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat' make[1]: *** [mancmd] Error 2 make[1]: Leaving directory /home/rkrug/Documents/Projects/AlienSpread/trunc/grass/ASM/.tmp/ecolmod/6441.0/v.out.ascii.mat’
make: *** [/build/buildd/grass-6.4.1/dist.i686-pc-linux-gnu/scripts/v.out.ascii.mat] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
[Raster MASK present]
GRASS 6.4.1 (grass):~/Documents/Projects/AlienSpread > $LOCATION_NAME
GRASS 6.4.1 (grass):~/Documents/Projects/AlienSpread > grass -version
Cleaning up temporary files …
Starting GRASS …
/home/rkrug/Documents/Projects/AlienSpread/-version: Not a valid GRASS location
Hamish
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
