Hello guys,
I create ROI from scatter plot using Interactive input for supervised classification. I want to export data from ROI. But, I don’t find the menu or tool in Grass.
Could someone tell me the tool or menu in Grass?
mega
Hello guys,
mega
Hi:
The interactive supervised classification allows you to draw, by hand, polygons covering pixels of classes that you want to use in your classification. The scatterplot preview, like the histogram, is just for understanding how correlated two specific bands are, for use in preparing those polygon training areas. Once you have prepared the polygon classes, you can save that vector to GRASS (the “Export training areas to map” button), then you run the (first step) in the classification process: creating the signature file. After the process finishes You must save the signature file (the next button on the toolbar) for use as input to the i.maxlik module (second step) to actually do the classification.
So it’s not clear what you “want to export from ROI”?
Perhaps if you explain what is your final goal, it might be easier for someone to help. There’s plenty of documentation on image classification that explains the procedure, for example, did you find this wiki page:
https://grasswiki.osgeo.org/wiki/Image_classification
On 1/4/21 7:00 AM, mega saputra wrote:
Hello guys,
mega
_______________________________________________ grass-user mailing list [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org) [https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
I want to mask cloud and land from band1 and band3, so that I wil get the ocean with clear cloud. To do that, I can create ROI from scatter plot. I want to know DN from ROI selection. So, I can create formula from DN range.
mega
On Tue, Jan 5, 2021 at 5:46 AM Micha Silver <tsvibar@gmail.com> wrote:
Hi:
Hello guys,
mega
-- Micha Silver Ben Gurion Univ. Sde Boker, Remote Sensing Lab cell: +972-523-665918
