[GRASS-user] Export/define region with Map Scale
Greetings
At GIS Map Display window it’s possible to define map scale in the bottom bar. I would like to know is:
1- Is it possible to export and plot maps (rasters/vectorials) with this map scale definition?
2- Is it possible to set region using this map scale definition in order to have by default this setting?
Thanks
Best Regfards
Franz
Franz Schiller wrote:
At GIS Map Display window it's possible to
note that it is probably wrong. in order for it to be right
the exact distance across your monitor would have to be known
as Scale is the ratio of distance on map to distance on ground.
If the distance on the screen (in ground units) isn't known,
you can't do that calculation. Typically the system (be it X11
or MS Windows) has a rough idea of the dpi, but it's probably
+/- 30% and not very reliable.
Some software like the GIMP have a calibration tool where you
can make it a bit better (until you change resolution settings
or use a different monitor). but most software just give you
a very rough approximate and hope you don't notice/care.
IMO that scale in the map display window is misleading and
should be disabled. (just because lots of other gis software
pretend to support this doesn't mean we should too; borrowing
the monitor calibration tool idea from GIMP is another option)
is:1- Is it possible to export and plot maps
yes. the ps.map module knows its output plots will be on paper,
and it knows how big that piece of paper is. therefore it can
correctly calculate and use the scale for PostScript (and so
PDF format too) hardcopies.
not directly, but you could write a script wrapping g.region
and d.info which after calibration could keep you somewhat
close to your desired scale. That's probably more trouble than
it's worth though.
Hamish
Greetings Hamish
Ok. So I just need to define the scale-output . Seems reasonably and easy :slight_smile:
close to your desired scale. That’s probably more trouble than
it’s worth though.
yes. It seems to. It seems easier to define Scale only in the output
Thanks
Franz
Hamish
