Hello!
How can I export multiple raster files created with r.basin with r.out.arc ( I need them to have *.asc extension). Is there a command line to do this in batch mode because I have around 170 files and it is a bit tedious. Please help.
Thank you,
Bogdan Rosca
Hi there,
The best way to do it would be with a script (the simplest being a bash script, but you can script your commands in any language you like). Either just by writing all of the commands into a file and then running the file (e.g.:
r.out.arc map=something
r.out.arc map=something_else
r.out.arc map=last_map
Or by processing the output of ‘g.list rast’ and then doing what you want with that. Hope that helps!
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions GbR
Vertreten durch: Daniel Lee, Nepomuk Reinhard und Nils Räder
Softwarecenter 3
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee@isi-solutions.org
Web: http://www.isi-solutions.org
2012/5/31 Rosca Bogdan <roscao@gmail.com>
Hello!
Thank you,
Bogdan Rosca
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, May 31, 2012 at 9:40 AM, Rosca Bogdan <roscao@gmail.com> wrote:
Hello!
Thank you,
Bogdan Rosca
The only way that I know, it’s with a script. Here is an example that you can use:
- Create a plain text with the names of your input maps, line by line:
map_name_1
map_name_2
map_name_3
If your maps have a pattern, like the example above, you can use the next line to create the file:
g.mlist type=rast pattern=map_name* > names
- This a little script that would be useful for you purpose. Just put it on the terminal
i=1
for VAR in awk '{print}' names
do
r.out.arc in=$VAR out=$VAR"arc"$i
i=expr $i + 1
done
I hope it helps you
David Montoya González
Ing. Forestal, Universidad Nacional de Colombia
Laboratorio de Sistemas Complejos, UNAL Medellin
I’ll have to defer that to the list, I’m not too good at bash scripting:
Well, yes I was thinking to that but I don’t know exactly how to do it. I mean, till now with:
g.mlist -r type=rast pattern=‘fill_mnat’
I have managed to see all rasters that I want to export (fill_mnat - is contained in the middle of the name of all files for export).
Next I think I have to run something like:
for map in g.mlist -r type=rast pattern=‘fill_mnat’ do r.out.arc input=$map output=‘basemap $map .asc’ done but nothing happens. Is this the correct command line?
Try like this:
RASTS=g.mlist rast pat="*fill_mnat*"
for r in $RASTS; do
echo “Processing raster $r”
g.region rast=$r
r.out.asc $r out=$r.asc
done
Note the backticks (`) in the first line.
Also, be aware that some software reads the asc header as cell centers and some as cell corners. GRASS outputs each pixel to the asc file as cell corners. If you need it as centers, add a ‘-c’ to the r.out.asc command.
You are missing some quotes. Try this:
for map in g.mlist -r type=vect pattern='fill_mnat'
do
r.out.arc in=$map out=basemap_$map".asc" type=area
done
Ooops, typo error: r.out.arc NOT r.out.asc
Try like this:
RASTS=
for r in $RASTS; do
g.region rast=$r
