[GRASS-user] Export multiple rasters into a single textfile
what is the fastest/most convenient way to export multiple rasters into a simple single text file (e.g. csv) so that the rows represent the single cells and the columns the values of the single rasters at that specific cell? The rasters (n=12) have all the same resolution and consist of each appr. 250000 cells.
What came into my mind was to generate a point-vector (center points of each raster cell) and then query all rasters at the locations of these points (250000) but I think there must be a more direct way available in GRASS?
Any ideas?
/Johannes
Hi!
gdal2xyz.py from gdal has a -csv switch
(Though never tested the -csv by myself, but the script itself works nicely)
It is not exactly what you want but might be a start if no one else
comes up with a GRASS solution.
should be doable to create a script that integrates gdal2xyz and
combines the values afterwards..
kind regards
Werner
On Wed, Nov 20, 2013 at 3:00 PM, Johannes Radinger
<johannesradinger@gmail.com> wrote:
appr. 250000 cells.
Any ideas?
/Johannes
grass-user mailing list
grass-user@lists.osgeo.org
appr. 250000 cells.
GRASS?
Any ideas?
Without reading very closely (apologies), did you check r.out.xyz? It's it's
doing the job, just loop it over the maps of interest.
Best, Nikos
On 20/11/13 14:00, Johannes Radinger wrote:
GRASS?
r.stats -1 input=raster1,raster2,etc
Moritz
Hi
Did you check r.stats -1 -g
It should do exactly what you want…
Stefan
Any ideas?
/Johannes
