[GRASS-user] Export specific shapes from a vector file
I need to export specific shapes from a grass vector file to another grass
vector file.
Also, I need to convert specific polygons from a vector grass file to a
raster grass file.
How can I do that?
Thanks, Leonidas
View this message in context: http://n2.nabble.com/Export-specific-shapes-from-a-vector-file-tp2337165p2337165.html
vector file.
v.extract in=VectorMap out=ExtractedFeatures ...
# you can use "list=" to extract specific categories (the "cat" column)
# or an SQL where clause, e.g. something like
"where='SomeColumn="SomeString"'
raster grass file.
I assume by polygons you mean areas.
v.to.rast in=VectorMap out=RasterMap type=area ...
# "use=???" You need to decide which values you will assign to your
pixels.
How can I do that?
Thanks, Leonidas
Regards, Nikos
Thank you Niko,
well I understand the first one (using v.extract).
-Is it possible to do something like that using v.out.ogr and export to
shapefile?
-As far as concerns the second question using v.to.rast, how can I export
only specific areas using sql where clause or list for specific categories?
Thanks again, Leonidas
grass
vector file.
raster grass file.
pixels.
How can I do that?
Thanks, Leonidas
Regards, Nikos
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/Export-specific-shapes-from-a-vector-file-tp2337165p2337293.html
On Mon, 2009-02-16 at 13:14 -0800, leonidas wrote:
Thank you Niko,
shapefile?
AFAIK, no. The way to do it is: v.extract + v.out.ogr
Apologies, I overlooked the word "specific" before. Here (again) I think
you would need v.extract + v.to.rast. An example:
Let's say you have the CORINE map in whose attribute table you have a
column named "level3" of type integer (with a lentgh of 3) which
contains the CORINE land cover class codes (111,112,113, etc.).
And now you need to extract specific classes, that is areas with
specific "level3" codes (i.e. 111, 112, 122, 123, 141, 142). Then you
could do:
v.extract in=corine_ellas_v2 out=corine_ellas_v2_subset
where='"level3"="111" or "level3"="112" or "level3"="112" or
"level3"="122" or "level3"="123" or "level3"="141" or "level3"="142"'
--o
then
v.to.rast in=corine_ellas_v2_subset out=corine_ellas_v2_subset use=attr
column=level3
Hope that helps
Cheers, Nikos
Yes that was what exactly I need.Thanks again
Thank you Niko,
shapefile?
categories?
could do:
--o
then
column=level3
Hope that helps
Cheers, Nikos
View this message in context: http://n2.nabble.com/Export-specific-shapes-from-a-vector-file-tp2337165p2337658.html
Λεωνίδα,
you might be interested in this tutorial:
Αναπαραγωγή του χάρτη CORINE με το GRASS-GIS
(http://users.hol.gr/~dzach/tilaphos/corine_grass-gis_el.pdf)
published at http://tilaphos.blogspot.com/2009/02/gis-corine.html
Χαιρετίσματα, Νίκος
Thanks, very interesting and useful job,
Καλό Τσίκνισμα, Λεωνίδας:-D
View this message in context: http://n2.nabble.com/Export-specific-shapes-from-a-vector-file-tp2337165p2354772.html
