Hamish wrote:
> I've got a grass vector map containing some areas with holes.
> after exporting with 'v.out.ogr type=area' to a shapefile, when I load
> the shp file into QGIS 0.8.1 I see that all the holes have been filled
> in.
> what am I doing wrong?
Markus Metz:
Maybe use v.out.ogr -c?
yup, that's it. I'd focused on the shapefile example in the man page
and totally missed the blinking red letters at the top:
<h2>NOTES</h2>
To export areas with holes into, e.g., a Shapefile, while keeping the
holes as holes, the flag <em>-c</em> has to be used.
> in.
Markus Metz:
I am also regularly missing that (and only now understand how to
solve this island problem).
Any chance to generate a warning if islands are there and -c not
given? Only then the problem + solution is obvious...
Markus Metz:
Hmm, what is the most common desired situation? Exporting features also if they don't have a category or only exporting features with a category?
In the case of areas I guess that areas without centroids (typically (parts of) islands) should most commonly appear as holes and not as filled areas. I assume that points and lines usually have categories, so the -c flag should generally not make a difference. Boundaries usually don't have categories (although they can), and exporting boundaries as lines is a special case.
My question is if the behaviour of v.out.ogr could be changed for grass7 to export only features with categories by default if this is the most common situation, e.g. invert the meaning of the -c flag.
Markus Metz:
Markus Metz:
So what would then happen if you export a vector which includes closed boundaries which have no cat, and centroids with the cat value? (and you request type=area)??
Micha
In this case you would get a proper, filled area, because the area has a cat. Querying the exported vector would give you all the info for that area that you would also get in grass with the original vector, no information is lost.
Boundaries in grass usually don't have cats, and if they have, they are not used for linking area attributes. In grass, only the centroid's cat is used for linking to area attributes.
On Thu, Apr 9, 2009 at 11:01 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
A nice example is Italy...
GRASS 6.5.svn (LL):~ > v.out.ogr italy_country dsn=italy.shp type=area
Exporting 26 areas (may take some time)...
100%
31 features written
WARNING: 5 features without category were written
GRASS 6.5.svn (LL):~ > v.out.ogr -c italy_country
dsn=italy_with_islands.shp type=area
100%
21 features written
WARNING: 5 features found without category were skipped
+ if (Vect_get_num_islands(&In) > 0 && !cat_flag->answer)
+ G_warning(_("The map contains islands. To preserve them in the
output map, use the -c flag"));
/* fetch PROJ info */
G_get_default_window(&cellhd);
if (cellhd.proj == PROJECTION_XY)
WARNING: The map contains islands. To preserve them, use the -c flag
100%
31 features written
100%
31 features written
100%
21 features written
100%
31 features written
Makes sense?
To me, yes. But I think that (in addition) for grass7, we should go for Markus M's suggestion of making -c the default (i.e. inversing the meaning of the flag).
