Dear all,
I have a vector map with its attributes on GRASS
and I would like to export only the table (not the vector),
and select some fields during the export.
Is there a way of do it on GRASS?
Kind regards
miltinho astronauta
brazil
Dear all,
Kind regards
miltinho astronauta
brazil
On Fri, 2008-08-01 at 16:19 -0300, Milton Cezar Ribeiro wrote:
2008/8/1, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
Hi Milton.
If you use sqlite as DBMS you can open your sqlite.db file
with
sqlitebrowser and export your table of interest as a .csv
file. Later
you can import for example in openoffice for further editing.
Milton, I assume it works for you this way. Anyway, I am writing back to
note that it was not my intention NOT to cc in the list. For some reason
I don't hit always the reply-to-all button lately :-?
Cheers, Nikos
[...]> 2008/8/1, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
> Hi Milton.
> with
> file. Later
> you can import for example in openoffice for further editing.[...]
db.select should do what you want. I use it regularly to make CSV file for
export.
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
On Fri, Aug 1, 2008 at 8:41 PM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Dear all,
and select some fields during the export.Is there a way of do it on GRASS?
Yes: db.out.ogr
Description:
Exports attribute tables into various formats.
[...]2008/8/1, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
Hi Milton.
with
file. Later
db.select should do what you want. I use it regularly to make CSV file for export.
Or (maybe easier): v.db.select.
Moritz
Thanks to all your help,
Several of your suggestions solved my problem with this task.
Kind regards,
miltinho astronauta
brazil
2008/8/2, Moritz Lennert <mlennert@club.worldonline.be>:
[…]2008/8/1, Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
Hi Milton.
with
file. Later
you can import for example in openoffice for further editing.[…]
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
