[GRASS-user] External raster from PostGIS
Hello,
I’m tryng to import a raster file sotred in PostGIS with r.external but i cannot select the db. If I try with r.in.gdal and i connect to the db I can’t see the table.
Any suggestion?
Lorenzo
On Thu, Oct 22, 2015 at 12:49 PM, Lorenzo Bottaccioli
<lorenzo.bottaccioli@gmail.com> wrote:
Hello,
I'm tryng to import a raster file sotred in PostGIS with r.external but i
can't see the table.
Can you please post the full command? (omitting the password if given there)
Is it similar to what's given in
https://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html#a3.2-Readingrasterdatafromthedatabase
I would like to add an example to the manual page but do not have a PG
installation containing a raster map.
Hi Markus,
How do I implement such command in GRASS GIS? I have tried with r.external because I have done the same thing with v.external. I’have tried as well with r.in.gdal but notthing. If i use v.in.ogr I can import vectors from PostGIS.
Lorenzo
2015-10-22 17:55 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hello,
Is it similar to what’s given in
Hi Lorenzo,
On Thu, Oct 22, 2015 at 6:03 PM, Lorenzo Bottaccioli
Hi Markus,
because I have done the same thing with v.external. I'have tried as well
PostGIS.
I would just like to the command to use. And the error message.
Perhaps we see why it fails.
Did you use "source=..." of r.external?
Hi Markus,
I did not try with any command in the command line, I’have just tried with the GUI of r.in.gdal selecting database. Can you give a suggestion for the use of “source=” option in the command line of r.external in order to select data from a PostGIS db?
Tnx
Lorenzo
2015-10-22 18:34 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Lorenzo,
Hi Markus,
PostGIS.
Did you use “source=…” of r.external?
Hi Lorenzo
On Oct 23, 2015 2:43 PM, “Lorenzo Bottaccioli” <lorenzo.bottaccioli@gmail.com> wrote:
Hi Markus,
I was referring to r.external.
Best
Hi Markus,
I have tried to read the manual of r.external but is not clear how it works with DB, is very clear how it works with files. Using the GUI of r.external and connecting to the db i cannot see the raster map.
I’ve used v.external with DB and that one was easy.
Regards
lorenzo
2015-10-23 16:05 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Lorenzo
Hi Markus,
Best
On Oct 23, 2015 4:40 PM, “Lorenzo Bottaccioli” <lorenzo.bottaccioli@gmail.com> wrote:
Hi Markus,
as mentioned I would like to improve the manual. I am aware that your task is not explained yet.
And for this I asked you to tell us what you tried. There is a copy button in the GUI for that purpose.
Best
Hi Markus,
I don’t see any copy button in the GUI of r.external.
Tnx
2015-10-23 17:20 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Markus,
Best
On Fri, Oct 23, 2015 at 5:43 PM, Lorenzo Bottaccioli
Hi Markus,
I don't see any copy button in the GUI of r.external.
If you launch it from the command line, without parameters, you get
the "native" GUI of r.external which comes with the copy button.
best
&lt;
&gt; wrote:
Hi Markus,
here on my
GRASS version: 7.1.svn
GRASS SVN revision: 66569
only r.external --ui starts the UI with the copy button; r.external without
parameters starts here the wizzard and not the r.external own GUI
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/External-raster-from-PostGIS-tp5231932p5232294.html
Hi Markus,
I have done what you have asked me. But the GUi that you obtain with r.external --ui, asu suggested by Helmut, does not have any possibility to select the DB so I have tried taking inspiration from v.external and I have wrtitetn this comand that obviuosly does not work “r.external source=“PG:dbname=test_gis2 user=lorenzo” output=elev” where can I specify the layer that I have to select? can you give me an example of a wright use of the command?
best
Lorenzo
2015-10-23 18:40 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Hi Markus,
the “native” GUI of r.external which comes with the copy button.
best
