[GRASS-user] Extracting grey features from an image
Hello
I've got a black and white image with some grey features on it
I'd like to create a new image containing only these features so I can
vectorize them
i think that I have to use
r.mask
r.mapcalc
or
r.reclass
r.describe raster
returns me
0-121 123 125-127 132-255
I created a mask of my image
r.mask input=image maskcats="0 thru 121" -i
-i to invert the maskcats range
Only the grey features appear.
So, my grey features seem to have the 0-121 range category of values.
Considering that, how can I manage to create a raster map based only on
these values.
I used r.reclass like this:
r.reclass input=raster output=rasterRec
0 thru 121=1 black
*=NULL
But I didn't get any good result...
Any help would be greatly appreciated!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Extracting-grey-features-from-an-image-tp5107822p5107822.html
On 05/27/2010 12:59 PM, baobazz wrote:
Hello
vectorize them
r.mask
r.mapcalc
or
r.reclass
r.describe raster
returns me
If I understand you correctly, you have a grey-scale raster (values from 0-255) which is displayed in three colors, black, grey and white?
From the above there are cells with values from 0-255, the only values that do *not* appear are 122, 124, and 128-131.
Perhaps you can run r.describe -1 ( or r.stats -ap ) to output all the categories, one per line, to have a clear idea of what the original contains.
Now, if you need to separate out raster cells with certain category values, then vectorize it, you could do, i.e.:
# extract only values between 125 and 127
r.mapcalc grey_raster="if(orig_rast>=125 and orig_rast<=127, 1, null() )"
# All cells from 125-127 get the value '1' in the new raster. All others are null.
# convert to vector
r.to.vect in=grey_raster out=grey_polygons feature=area
This will clump together into a vector of polygons all raster cells that have values 125,126, or 127.
HTH
Micha
these values.
0 thru 121=1 black
*=NULL
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
Use r.mask as already done to identify your grey values only, then apply r.mapcalc "new_raster=if(MASK,orig_raster,null())".
Christian.
Sent: Thursday, May 27, 2010 11:59 AM
To: <grass-user@lists.osgeo.org>
Subject: [GRASS-user] Extracting grey features from an image
Hello
vectorize them
r.mask
r.mapcalc
or
r.reclass
r.describe raster
returns me
these values.
0 thru 121=1 black
*=NULL
grass-user mailing list
Thanks a lot for the answers!
I managed to identify the range of values containing the grey category
values.
So, my command became:
r.mapcalc grey_raster=if(tragh.red>=132&&tragh.red<=200, 1, null())
It was a little difficult.
I had to make it step by step.
One way would be to use in addition
r.what
or
r.what.vect
to sample the cat values corresponding to my grey zones
Thank you
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Extracting-grey-features-from-an-image-tp5107822p5108384.html
