I have two nearly identical line vectors, and I would like to extract the lines that differ between the two vectors into a third vector. Specifically, I want to isolate the connecting lines that were generated by v.net operation=connect. Something like:
[map_C = map_A NOT map_B] for line features.
I thought I would be able to use v.overlay with operator=not, but it it appears to require that btype=area. It also appears that v.select allows only operator=overlap.
Can someone point me in the right direction?
I am using William Kyngesburye's 6.4.0RC3 on MacOS 10.5.7.
-Dwight
Does anybody have a suggestion for subtracting the elements in one line vector from another line vector?
-D
On Jul 21, 2009, at 7:06 PM, Dwight Needels wrote:
-Dwight
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, Jul 22, 2009 at 1:06 AM, Dwight Needels<needels@translucida.com> wrote:
Since GRASS 6.5 there is GEOS support with more functionality available
in v.select, see also
http://lists.osgeo.org/pipermail/grass-user/2009-June/051142.html
This may be a way.
On 22/07/09 01:06, Dwight Needels wrote:
Unless you can try the new GEOS support Markus suggested, you can also try via a raster approach (untested):
v.to.rast A and B
r.mapcalc C=(if(A && isnull(B)), 1, null())
r.to.vect C
You will have to adjust your region settings (g.region) in order to make this work.
Moritz
