as mentioned before, I need to extract probability-values from i.maxlik
that are computed for each pixel for each class. Is there an 'easy' way
to achieve this? If I need to dig into the source code, can anybody help
me to find the right line in the right class? I'm not that much of a C
guru :-/
Thanks in advance!
Georg
On 24/03/09 11:35, Georg Kaspar wrote:
as mentioned before, I need to extract probability-values from i.maxlik that are computed for each pixel for each class. Is there an 'easy' way to achieve this? If I need to dig into the source code, can anybody help me to find the right line in the right class? I'm not that much of a C guru :-/
Me neither, and I do not understand all the math behind it, but I think you should look at imagery/i.maxlik/classify.c where the threshold of the reject map is calculated for each pixel.
Moritz
