[GRASS-user] exwcuting grass python script from php web page
Hi all!
I wrote a python script with grass to be run from a php web page.
The python script works perfectly if I run it from the terminal but when I try to run it from the php web page, the grass related part seems to be ignored and the grass session is not launched. I set the grass gis environment following this link [0].
From the php side, I try to launch the python script using both exec(), system() and also a bash script to run the python script but I always got the same error.
Attached you can find the python script.
Does anybody have any ideas on how to fix it?
Thanks in advance for the help!
Roberta
[0] https://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Python:_GRASS_GIS_7_with_existing_location
Working with GRASS without starting it explicitly - GRASS-Wiki - GRASS-Wiki - GRASS-Wiki
GRASS sessions. It is possible to access GRASS modules without explicitly starting a “GRASS session”. GRASS libraries require certain environment variables to be set. In fact a “GRASS session” is just a set of processes (e.g. a shell and/or GUI) which have the necessary environment settings, specifically:
grasswiki.osgeo.org
(attachments)
importgrass.py (2.04 KB)
On 28/09/20 12:10, roberta fagandini wrote:
Hi all!
Maybe you could tell us what error you get ?
Moritz
Sorry, maybe I didn’t explain myself well because actually, I don’t get any error from the php web page, simply the code related to grass is not executed.For instance gsetup.init(gisbase, gisdb, location, mapset) does not create any file in my /tmp/ folder and the print(gscript.gisenv()) is not printed.
I checked the import of the grass libraries (print(sys.modules)) and they seem to be correctly imported.
Da: Moritz Lennert mlennert@club.worldonline.be
Inviato: lunedì 28 settembre 2020 17:29
A: roberta fagandini robifagandini@hotmail.it; grass-user@lists.osgeo.org grass-user@lists.osgeo.org
Oggetto: Re: [GRASS-user] exwcuting grass python script from php web page
Hi all!
got the same error.
Moritz
On 28/09/20 17:51, roberta fagandini wrote:
Sorry, maybe I didn't explain myself well because actually, I don't get any error from the php web page, simply the code related to grass is not executed.For instance gsetup.init(gisbase, gisdb, location, mapset) does not create any file in my /tmp/ folder and the print(gscript.gisenv()) is not printed.
Have you checked your webservers error logs ?
How do you call the python script from PhP ?
Are you sure that your web server has sufficient permissions to access the relevant directories ?
Moritz
*Da:* Moritz Lennert <mlennert@club.worldonline.be>
*Inviato:* lunedì 28 settembre 2020 17:29
*A:* roberta fagandini <robifagandini@hotmail.it>; grass-user@lists.osgeo.org <grass-user@lists.osgeo.org>
*Oggetto:* Re: [GRASS-user] exwcuting grass python script from php web page
Hi all!
Moritz
is not printed.
I have already checked and this is the error in the webserver log file
File "importgrass.py", line 82, in <module>
    main()
  File "importgrass.py", line 71, in main
    rcfile = gsetup.init(gisbase, gisdb, location, mapset)
  File "/usr/lib/grass74/etc/python/grass/script/setup.py", line 170, in init
    config_dir = os.path.join(os.getenv('HOME'), config_dirname)
  File "/usr/lib/python3.6/posixpath.py", line 80, in join
    a = os.fspath(a)
TypeError: expected str, bytes or os.PathLike object, not NoneType
How do you call the python script from PhP?
I tried both with:
<?php
       $command = escapeshellcmd('/usr/bin/python3 importgrass.py ');
        echo exec($command, $output, $return);
and
<?php
        echo system($command, $return);
and
<?php
       $intestazione='#!/bin/bash'.PHP_EOL;
       $myfile = fopen("./tmp/script.sh", "w") or die("Unable to open file!");
       fwrite($myfile, $intestazione);
       fwrite($myfile, $command);
       fclose($myfile);
       echo exec("/bin/sh ./tmp/script.sh", $output, $return);
       print_r($output);
Yes, I'm pretty sure! If I run the python script from terminal as www-data it works perfectly.
Moritz
Thanks!
Roberta
Hi all!
got the same error.
Moritz
Hi Roberta,
I'm really no expert in this domain, so just doing some educated guessing.
main()
a = os.fspath(a)
First of all, the importgrass.py you sent only has 72 lines, so I don't know what the line 82 reference in your above error points to.
But most importantly, I would really recommend that you upgrade to a newer version of GRASS GIS. Current stable is 7.8. There's been a lot of improvement in terms of python3 compatibility and maybe this is an issue that has already been resolved.
It sounds like an issue with a variable containing a path. Apparently it is of type NoneType...
I tried both with:
<?php
and
<?php
and
<?php
fclose($myfile);
print_r($output);
What happens when you replace '/usr/bin/python3 importgrass.py ' by, for example '/usr/bin/grass --version', just to check if other executables work ?
Moritz
Hi Moritz,
Hi Roberta,
I’m really no expert in this domain, so just doing some educated guessing.
is not printed.
File “importgrass.py”, line 82, in
main()
File “importgrass.py”, line 71, in main
File “/usr/lib/grass74/etc/python/grass/script/setup.py”, line 170,
in init
config_dir = os.path.join(os.getenv(‘HOME’), config_dirname)
File “/usr/lib/python3.6/posixpath.py”, line 80, in join
a = os.fspath(a)
First of all, the importgrass.py you sent only has 72 lines, so I don’t
This is simply due to some print that I added to the code before checking the error log.
newer version of GRASS GIS. Current stable is 7.8. There’s been a lot of
is of type NoneType…
I tried to upgrade GRASS using the repository ubuntugis unstable but it caused some problems with the installation of postgis. Do you have another solution?
I tried both with:
<?php $command = escapeshellcmd('/usr/bin/python3 importgrass.py '); echo exec($command, $output, $return); ?>
and
<?php $command = escapeshellcmd('/usr/bin/python3 importgrass.py '); echo system($command, $return); ?>
and
<?php $intestazione='#!/bin/bash'.PHP_EOL; $command = escapeshellcmd('/usr/bin/python3 importgrass.py '); $myfile = fopen("./tmp/script.sh", "w") or die("Unable to open file!"); fwrite($myfile, $intestazione); fwrite($myfile, $command); fclose($myfile); echo exec("/bin/sh ./tmp/script.sh", $output, $return); print_r($output); ?>
What happens when you replace '/usr/bin/python3 importgrass.py ’ by, for
example ‘/usr/bin/grass --version’, just to check if other executables
work ?
I tried to run ‘/usr/bin/grass --version’ but I got a similar error:
File “/usr/bin/grass”, line 2005, in
main()
File “/usr/bin/grass”, line 1804, in main
grass_config_dir = get_grass_config_dir()
File “/usr/bin/grass”, line 398, in get_grass_config_dir
directory = os.path.join(os.getenv(‘HOME’), grass_config_dirname)
File “/usr/lib/python2.7/posixpath.py”, line 70, in join
elif path == ‘’ or path.endswith(‘/’):
AttributeError: ‘NoneType’ object has no attribute ‘endswith’
Moritz
Thanks again!
Roberta
Hi Roberta,
On Wed, Sep 30, 2020 at 5:12 PM roberta fagandini
>> is not printed.
I observe that:
> main()
... you use GRASS GIS 7.4? Pretty old and outdated.
> in init
... you try to use GRASS GIS 7.4 with Python 3. For this you need
GRASS GIS 7.8 as already suggested.
> a = os.fspath(a)
Which problems exactly?
... Python 3, fine. But here:
I tried to run '/usr/bin/grass --version' but I got a similar error:
File "/usr/bin/grass", line 2005, in <module>
    main()
  File "/usr/bin/grass", line 1804, in main
  File "/usr/bin/grass", line 398, in get_grass_config_dir
    directory = os.path.join(os.getenv('HOME'), grass_config_dirname)
  File "/usr/lib/python2.7/posixpath.py", line 70, in join
... again Python 2.
This mixture will not work. Do you have by chance multiple GRASS GIS
versions installed?
I'd suggest removing all installed GRASS packages and reinstalling 7.8
cleanly again.
best
Hi Markus!
We compiled GRASS 7.8 and this solved the problem of python3/python2 but we got the same error:
File “importgrass78.py”, line 79, in
main()
File “importgrass78.py”, line 68, in main
File “/usr/local/grass78/etc/python/grass/script/setup.py”, line 175, in init
a = os.fspath(a)
This issue is due to running the GRASS script from php since the server is not able to retrieve the HOME path of the user www-data. Therefore, we modified the setup.py script specifying the home path in a new variable:
add addons to the PATH
copied and simplified from lib/init/grass.py
if mswin:
config_dirname = “GRASS7”
config_dir = os.path.join(os.getenv(‘APPDATA’), config_dirname)
else:
user_home = ‘/home/ubuntu/’
config_dirname = “.grass7”
config_dir = os.path.join(user_home, config_dirname)
After these changes, we were able to run GRASS from a php web page but we got a new error using certain modules like v.in.ogr:
Check if OGR layer <sql_statement> contains polygons…
0%^H^H^H^H^H 33%^H^H^H^H^H 66%^H^H^H^H^H 100%^H^H^H^H^H
WARNING: Vector map already exists and will be overwritten
Creating attribute table for layer <sql_statement>…
ERROR: Unable to determine user’s home directory
File “path3d.py”, line 297, in
main()
File “path3d.py”, line 267, in main
gscript.run_command(‘v.in.ogr’, input=‘{}/tmp/output.gpkg’.format(outdir0), layer='sql_statement$
File “/usr/local/grass78/etc/python/grass/script/core.py”, line 441, in run_command
return handle_errors(returncode, returncode, args, kwargs)
File “/usr/local/grass78/etc/python/grass/script/core.py”, line 343, in handle_errors
returncode=returncode)
The error is always the same, the php web page is not able to retrieve the home path. We solved this error setting the server home path as HOME environment variable. Adding the following lines to our GRASS python script, everything works fine and we are now able to run the script from our php web page!
os.environ[‘HOME’] = home
Hope this can help in case anyone has the same problem!
Regarding the problem installing GRASS GIS from ubuntugis unstable, I don’t know exactly what te problem is, but using ubuntugis unstable caused some conflicts with Postgis and QGIS server packages respectively installed using https://wiki.postgresql.org/wiki/Apt and https://qgis.org/ubuntu-ltr
Thanks again for yout help and your suggestions!
Roberta
Da: Markus Neteler neteler@osgeo.org
Inviato: domenica 4 ottobre 2020 11:04
Cc: Moritz Lennert mlennert@club.worldonline.be; grass-user@lists.osgeo.org grass-user@lists.osgeo.org
Oggetto: Re: [GRASS-user] R: exwcuting grass python script from php web page
Hi Roberta,
is not printed.
I observe that:
main()
… you use GRASS GIS 7.4? Pretty old and outdated.
in init
… you try to use GRASS GIS 7.4 with Python 3. For this you need
a = os.fspath(a)
… Python 3, fine. But here:
main()
… again Python 2.
versions installed?
I’d suggest removing all installed GRASS packages and reinstalling 7.8
cleanly again.
best
Hi Roberta,
Glad you got it working!
Would you mind adding your findings here?
https://grasswiki.osgeo.org/wiki/GRASS_and_PHP
