[GRASS-user] face to DEM?
I have some 3-d vector faces. They were defined in a text file like this:
F 10
1 2 1
2 2 2
etc.
I imported them into grass like this:
v.in.ascii -zn input=faces.txt out=faces format=standard
and all seems fine.
I can see the faces, and if I click on points around the edges I can get a height as well.
I can't figure out how to generate a raster DEM from these faces. Essentially I would like to know the approximate elevation at each raster point inside the faces.
I tried v.to.rast but then I get "Column parameter missing"
For v.to.rast3 I get "Unable to get layer info for vector map"
I also tried v.extrude but I see all 0s (ie Number of areas: 0 etc.)
Did I do something wrong on my import? Did I miss some other way to do the conversion?
I want to be able to do some mapcalcs with the heights of an these faces compared to another raster map, but I can't figure out how to convert these faces to something that I can work with.
Thanks much,
--Adam
Hello Adam,
hope I understood what you mean to do. If I had to cope with your
problem, I would import the source file as points, then run v.to.rast,
and r.surf.nnbathy with the "l" interpolation method.
The risk for this solution is the triangulation performed by
r.surf.nnbathy be different from your source TIN...
Good luck,
Vincent.
this:
F 10
1 2 1
2 2 2
etc.
and all seems fine.
do the conversion?
Thanks much,
--Adam
grass-user mailing list
grass-user@lists.osgeo.org
you can try v.surf.rst as well
j
Vincent Bain píše v Ne 15. 02. 2009 v 10:32 +0100:
Hello Adam,
Good luck,
Vincent.
> this:
> F 10
> 1 2 1
> 2 2 2
> etc.
> and all seems fine.
> do the conversion?
> Thanks much,
> --Adam
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Thanks. I did, but didn't have any luck. In one case I ended up making some pretty art, but it wasn't helpful. The problem was that it included all the stuff outside of the face, as well as "inside" where it should have covered and I need.
And I just tried it again, with another simple shape and a different map, and this time, even though I first set the region to match the input map, I am still getting "strip exists with insufficient data. ERROR2: zero point in the given region! Input failed."
--Adam
On Feb 20, 2009, at 2:12 AM, Jachym Cepicky wrote:
j
Hello Adam,
Good luck,
Vincent.
this:
F 10
1 2 1
2 2 2
etc.
and all seems fine.
do the conversion?
Thanks much,
--Adam
Jachym Cepicky
