[GRASS-user] failing to import table
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
Importing a shapefile with space in the name results in an empty table of attributes.
Is this a known problem? Should I file a ticket?
GRASS 6.4.2-2 from Debian unstable.
Thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlIgWTAACgkQ/NedwLUzIr5WjwCdE2LpHK77nWhC0v5+yC2frlcm
ITkAn2/3HgE4xBWj0k3F4O+nRfJMzT3b
=XaQr
-----END PGP SIGNATURE-----
Hash: SHA1
Hi all.
I don't get an empty table of attributes, but an erroneous db table connection info.
https://trac.osgeo.org/grass/ticket/1328
Apparently it needs to be reopened ?
Moritz
does this persist with the current 6.4.3?
Hash: SHA1
untested - I cannot publish the data, but can send it you you are interested to check.
thanks.
www.faunalia.eu
iEYEARECAAYFAlIiILgACgkQ/NedwLUzIr6NpgCfXg+VJqLfi7NAYI1Xdvd3dNrS
Q1AAn3kkyEC7wznobqN1j2qZjtNfwokQ
=Mi1N
On Sat, Aug 31, 2013 at 6:58 PM, Paolo Cavallini <cavallini@faunalia.it> wrote:
Hash: SHA1
Due to time constraints at my end please test with the current stable
version first.
thanks
Hash: SHA1
version first.
Unfortunately it is currently not possible for me right now. If there is anybody with
a clean 6.4.3, I'll be happy to provide the file.
Thanks a lot.
www.faunalia.eu
iEYEARECAAYFAlIjATgACgkQ/NedwLUzIr4P2wCfVjtWyX23EWzBVQsUksXz2xuM
lLcAnRAvTjJgBOgjoc7q+OkwTH8cV10c
=zibT
version first.
anybody with
Thanks a lot.
tested with
GRASS Version: 6.4.3
GRASS SVN Revision: 57300M
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.8.0, 6 March 2012
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
v.in.ogr dsn=J:\wd\grassshape\a b.shp output=a_b
Die Projektionsinformationen des Eingabedatensatzes und der aktuellen
Location scheinen übereinzustimmen.
Layer: a b
Zähle Polygone für 71 Objekte...
Importiere 71 Objekte der Karte...
Erstelle Topologie für die Vektorkarte <a_b_tmp>...
Registriere Primitive...
71 Primitive registriert
71 Vertices registriert
Anzahl der Knoten: 71
Anzahl der Primitive: 71
Anzahl der Punkte: 71
Anzahl der Linien: 0
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: -
Anzahl der Inseln: -
Erstelle Topologie für die Vektorkarte <a_b>...
Erzeuge Flächen...
0 Flächen angelegt
0 Inseln angelegt
Füge Inseln hinzu...
Füge Zentroide hinzu...
Anzahl der Flächen: 0
Anzahl der Inseln: 0
import (also attribute table) works here
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/failing-to-import-table-tp5075176p5075450.html
just to note that Frankie & me hope to have the 6.4.3 package into debian/unstable
in the coming days.
remaining issue has to do with subtleties of
http://packages.debian.org/sid/libtiff5-alt-dev
regards,
Hamish
On 31/08/13 13:56, Markus Neteler wrote:
I tested with post-6.4.3-release 64 release branch and it does persist.
Moritz
Hash: SHA1
Thanks - should I open a ticket then?
All the best.
www.faunalia.eu
iEYEARECAAYFAlIkOqIACgkQ/NedwLUzIr4UhACcCZy2KD9axwYj7uuGFY8IXs0W
g3MAn17xPMu6O3/92x5Wx/o78BftnTxZ
=9W6o
GDAL/OGR: 1.9.2
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W) uote author="Moritz Lennert">
Moritz
grass-user mailing list
grass-user@.osgeo
it works for me with
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/failing-to-import-table-tp5075176p5075536.html
GDAL/OGR: 1.9.2
Python: 2.7.4
wxPython: 2.8.12.1
Lennert">
Moritz
grass-user@.osgeo
sorry, too early sent.
it works with osgeo4w-winGRASS6.4.3
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/failing-to-import-table-tp5075176p5075537.html
Hash: SHA1
As mentioned, this really resembles https://trac.osgeo.org/grass/ticket/1328, so I think it could just be reopened.
Moritz
version first.
anybody with
Thanks a lot.
tested with
GDAL/OGR: 1.9.2
Python: 2.7.4
wxPython: 2.8.12.1
Layer: a b
Erstelle Topologie für die Vektorkarte<a_b_tmp>...
Erstelle Topologie für die Vektorkarte<a_b>...
Erzeuge Flächen...
0 Flächen angelegt
0 Inseln angelegt
Have you tried accessing the attribute table ? Working with it through other modules ?
What does v.db.connect -p give you ?
Moritz
other modules ?
attribute table manager opens without any problems, some further tests below
_____
System Info
GRASS version: 6.4.3
GRASS SVN Revision:
GDAL/OGR: GDAL 1.9.2, released 2012/10/08
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
_____
nc-sample data set
v.out.ogr -s -e input=geology@PERMANENT type=area dsn=C:\wd olayer=a_b
_____
renaming
a_b.shp => a b.shp
a_b.dbf => a b.shp
a_b.prj => a b.shp
a_b.shx => a b.shp
_____
v.in.ogr dsn=C:\wd\a b.shp output=import_shapefile_with_spaces
Projection of input dataset and current location appear to match
Layer: a b
Counting polygons for 1832 features...
Importing map 1832 features...
Building topology for vector map <import_shapefile_with_spaces_tmp>...
Registering primitives...
6462 primitives registered
322207 vertices registered
Number of nodes: 5733
Number of primitives: 6462
Number of points: 0
Number of lines: 0
Number of boundaries: 6462
Number of centroids: 0
Number of areas: -
Number of isles: -
WARNING: Cleaning polygons, result is not guaranteed!
Break polygons:
Remove duplicates:
Break boundaries:
Remove duplicates:
Clean boundaries at nodes:
Merge boundaries:
Change dangles to lines:
Remove bridges:
Building areas...
1832 areas built
907 isles built
Attaching islands...
Number of nodes: 6722
Number of primitives: 19851
Number of points: 0
Number of lines: 0
Number of boundaries: 19851
Number of areas: 1832
Number of isles: 907
Number of areas without centroid: 1832
Find centroids for layer: a b
Write centroids:
1832 input polygons
Total area: 1.27609E+011 (1832 areas)
Overlapping area: 0 (0 areas)
Area without category: 0 (0 areas)
Building topology for vector map <import_shapefile_with_spaces>...
5465 primitives registered
191205 vertices registered
Building areas...
1832 areas built
907 isles built
Attaching centroids...
Number of nodes: 4540
Number of primitives: 5465
Number of points: 0
Number of lines: 0
Number of boundaries: 3633
Number of centroids: 1832
(Mon Sep 02 10:59:28 2013) Command finished (12 sec)
_____
_____
v.db.connect map=import_shapefile_with_spaces -p
Vector map <import_shapefile_with_spaces@user1> is connected by:
layer <1> table <import_shapefile_with_spaces> in database
<C:\grassdata\nc_spm_08\user1\dbf\> through driver <dbf> with key <cat>
_____
v.report map=import_shapefile_with_spaces@user1 option=area units=hectares
Displaying column types/names for database connection of layer 1:
cat|onemap_pro|PERIMETER|GEOL250_|GEOL250_ID|GEO_NAME|SHAPE_area|SHAPE_len|area
1|141526064|232209.09375|12|11|Qp|141526058.758|232209.096991|14152.6058758046
2|163779.1875|1767.666138|14|13|Qp|163779.303257|1767.666078|16.3779303256575
3|45783944|43256.566406|15|14|Qp|45783948.3426|43256.564356|4578.39483425879
_____
v.db.addcol --verbose map=import_shapefile_with_spaces@user1 columns=ncoladd
integer
(Mon Sep 02 11:05:37 2013) Command finished (1 sec)
_____
db.columns --verbose table=import_shapefile_with_spaces
cat
onemap_pro
PERIMETER
GEOL250_
GEOL250_ID
GEO_NAME
SHAPE_area
SHAPE_len
ncoladd
(Mon Sep 02 11:09:08 2013) Command finished (0 sec)
_____
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/failing-to-import-table-tp5075176p5075573.html
Hash: SHA1
other modules ?
Thanks for the tests. So it seems that this is sometimes working, sometimes not,
right? What could be the reason?
All the best.
www.faunalia.eu
iEYEARECAAYFAlIkjoMACgkQ/NedwLUzIr41kACdE3P/G58Ytb7qXIFtmnVad+9D
EfUAn2ic0pVlYJxtTlVJYjZQtcSy/XxM
=Gvxi
Hash: SHA1
other modules ?
I've just tried again with a freshly checked out and compiled grass64 release branch. I cannot reproduce the error. I'm not sure what might have caused it in my previous run, but at least in the current release branch (and thus 6.4.3 probably) it seems to be working.
Sorry for the noise...
Moritz
Hash: SHA1
be working.
ok, thanks; I'll check again as soon as 6.4.3 hits Debian.
All the best.
www.faunalia.eu
iEYEARECAAYFAlIkk2MACgkQ/NedwLUzIr4YVQCfca+JAkfRdGaUoKCvPxyQkeql
W58AniC2aHf3EAA+gToy93VPI2kkRaIZ
=Shjh
