[GRASS-user] Failure to compile GRASS GIS 7.8 with Proj 6 and GDAL 3
Dears,
I cannot get GRASS GIS 7.8 to compile with
eselect gcc show
x86_64-pc-linux-gnu-9.2.0
make --version
GNU Make 4.2.1
zlib version 1.2.11-r3
eselect python show
python3.7
flex --version
flex 2.6.4
proj
Rel. 6.0.0, March 1st, 2019
geos-config --version
3.7.0
gdal-config --version
3.0.4
make distclean
./configure --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" --with-readline --with-geos
make
The `error.log` here: https://pastebin.com/rEgMmcPT
Running make from inside few directories with error(s): https://pastebin.com/PisKVBHP
Hi Nikos,
PROJ is moving fast, please use the latest PROJ 6 release 6.3.0
On Sat, Feb 1, 2020 at 8:36 PM Nikos Alexandris <nik@nikosalexandris.net> wrote:
Dears,
proj
if possible, never use a x.0.0 release of any software, these new major releases are usually full of bugs.
Markus M
3.7.0
3.0.4
make distclean
./configure --with-freetype=yes --with-freetype-includes=“/usr/include/freetype2/” --with-readline --with-geos
make
The `error.log` here: [https://pastebin.com/rEgMmcPT](https://pastebin.com/rEgMmcPT)
Running make from inside few directories with error(s): [https://pastebin.com/PisKVBHP](https://pastebin.com/PisKVBHP)
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Markus Metz:
Hi Nikos,
wrote:
Dears,
proj
Markus M
Thank you Markus!
I got it working, more or less. Recompiling only PROJ did away most of
the errors but a few. I guess I need to recompile PROJ (+GEOS), then
GDAL, then the rest.
Cheers, Nikos
Hi Nikos,
On Sun, Feb 2, 2020 at 10:40 AM Nikos Alexandris
Would you mind to then add/update the relevant section in
https://grasswiki.osgeo.org/wiki/Compile_and_Install
thanks
On 2020-02-02 10:40, Nikos Alexandris wrote:
Markus Metz:
Hi Nikos,
wrote:
Dears,
proj
Markus M
Thank you Markus!
Yes, IME the compile sequence to satisfy dependencies is (with optional in parentheses):
geos, proj, (netcdf), libgeotiff, (spatialite), GDAL, GRASS
* Nikos Alexandris <nik@nikosalexandris.net> [2020-02-02 10:40:11 +0100]:
Markus Metz:
Hi Nikos,
wrote:
Dears,
proj
Markus M
Thank you Markus!
Still need to fix a few more:
Errors in:
/osgeo/grass/general/g.proj
/osgeo/grass/general/g.region
/osgeo/grass/raster/r.horizon
/osgeo/grass/raster/r.sun
/osgeo/grass/raster3d/r3.out.netcdf
for DIRECTORY in /osgeo/grass/general/g.proj /osgeo/grass/general/g.region /osgeo/grass/raster/r.horizon /osgeo/grass/raster/r.sun /osgeo/grass/raster3d/r3.out.netcdf ;do cd $DIRECTORY && make ;echo ;done
: && gcc -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic  -L/usr/lib64/ -Wl,-rpath-link,/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -o /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/g.proj OBJ.x86_64-pc-linux-gnu/create.o OBJ.x86_64-pc-linux-gnu/datumtrans.o OBJ.x86_64-pc-linux-gnu/input.o OBJ.x86_64-pc-linux-gnu/list_codes.o OBJ.x86_64-pc-linux-gnu/main.o OBJ.x86_64-pc-linux-gnu/output.o    -lgrass_gproj.7.8 -lgrass_gis.7.8 -L/usr/local/lib -lgdal -L/usr/lib64/ -lproj    -lm
/usr/lib/gcc/x86_64-pc-linux-gnu/9.2.0/../../../../x86_64-pc-linux-gnu/bin/ld: /osgeo/grass/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.7.8.so: undefined reference to `proj_get_remarks'
/usr/lib/gcc/x86_64-pc-linux-gnu/9.2.0/../../../../x86_64-pc-linux-gnu/bin/ld: /osgeo/grass/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.7.8.so: undefined reference to `proj_normalize_for_visualization'
/usr/lib/gcc/x86_64-pc-linux-gnu/9.2.0/../../../../x86_64-pc-linux-gnu/bin/ld: /osgeo/grass/dist.x86_64-pc-linux-gnu/lib/libgrass_gproj.7.8.so: undefined reference to `proj_get_scope'
collect2: error: ld returned 1 exit status
make: *** [../../include/Make/Module.make:18: /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/g.proj] Error 1
: && gcc -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic  -L/usr/lib64/ -Wl,-rpath-link,/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -o /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/g.region OBJ.x86_64-pc-linux-gnu/adjust.o OBJ.x86_64-pc-linux-gnu/main.o OBJ.x86_64-pc-linux-gnu/printwindow.o OBJ.x86_64-pc-linux-gnu/zoom.o    -lgrass_gproj.7.8 -lgrass_vector.7.8 -lgrass_dig2.7.8 -lgrass_g3d.7.8 -lgrass_raster.7.8 -lgrass_gis.7.8 -lm  -L/usr/lib64/ -lproj    -lm
make: *** [../../include/Make/Module.make:18: /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/g.region] Error 1
: && gcc -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic  -L/usr/lib64/ -Wl,-rpath-link,/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -o /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/r.horizon OBJ.x86_64-pc-linux-gnu/main.o    -lgrass_gproj.7.8 -lgrass_raster.7.8 -lgrass_gis.7.8 -lm  -L/usr/lib64/ -lproj    -lm
make: *** [../../include/Make/Module.make:18: /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/r.horizon] Error 1
: && gcc -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic  -L/usr/lib64/ -Wl,-rpath-link,/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -o /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/r.sun OBJ.x86_64-pc-linux-gnu/main.o OBJ.x86_64-pc-linux-gnu/rsunlib.o    -lgrass_gproj.7.8 -lgrass_raster.7.8 -lgrass_gis.7.8 -lm  -lgrass_gmath.7.8 -L/usr/lib64/ -lproj  -lgomp   -lOpenCL  -lm
make: *** [../../include/Make/Module.make:18: /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/r.sun] Error 1
: && gcc -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -L/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -Wl,--export-dynamic  -L/usr/lib64/ -Wl,-rpath-link,/osgeo/grass/dist.x86_64-pc-linux-gnu/lib -o /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/r3.out.netcdf OBJ.x86_64-pc-linux-gnu/main.o    -lgrass_g3d.7.8 -lgrass_gproj.7.8 -lgrass_gis.7.8 -L/usr/local/lib -lgdal -L/usr/lib64 -lnetcdf -L/usr/lib64/ -lproj  -lgrass_datetime.7.8   -lm
make: *** [../../include/Make/Module.make:18: /osgeo/grass/dist.x86_64-pc-linux-gnu/bin/r3.out.netcdf] Error 1
Nikos
* Markus Neteler <neteler@osgeo.org> [2020-02-02 10:43:51 +0100]:
Hi Nikos,
Of course I will, but the https://trac.osgeo.org/grass/wiki/FuntooLinux
wiki page. Not the generic, which I think is still valid.
Nikos
* Nikos Alexandris <nik@nikosalexandris.net> [2020-02-03 18:15:31 +0100]:
Markus Metz:
Hi Nikos,
wrote:
Dears,
proj
Markus M
Thank you Markus!
Errors in:
Fixed, I had to remove left-over files from previous PROJ
installation(s).
(...why is there no `make uninstall` for PROJ, GEOS, etc.?)
Nikos
Hi Nikos,
On Mon, Feb 3, 2020 at 7:28 PM Nikos Alexandris <nik@nikosalexandris.net> wrote:
Errors in:
installation(s).
(…why is there no make uninstall for PROJ, GEOS, etc.?)
if you compile from source, it is mostly your responsibility to clean up old installations. Generally, cleaning up should happen in
${prefix}/lib[64]
${prefix}/include
${prefix}/share
regarding PROJ, cleaning up ${prefix}/share with the proj.db and grids is quite important because PROJ is evolving fast and any leftovers from a previous installation might confuse software compiled against PROJ.
Regarding GDAL compilation against PROJ, there was in GDAL 2 the configure option
–with-static-proj4=ARG Compile with PROJ.4 statically (deprecated, use --with-proj instead) (ARG=no or path)
in GDAL 3 there is only
–with-proj=ARG Compile with PROJ.x (ARG=yes or path)
This static proj linking in GDAL does not mean to link against a static PROJ library, but to statically link against a given dynamic PROJ library, i.e. the same PROJ library used at compile time will also be used at run time. This is important to make sure that GDAL is not suddenly picking a different PROJ library at run time when a new PROJ library becomes available.
I ran in all these problems myself when adding support for PROJ 4, 5, and 6 in GRASS.
Markus M
* Markus Metz <markus.metz.giswork@gmail.com> [2020-02-03 22:35:26 +0100]:
Hi Nikos,
>Errors in:
installation(s).
old installations.
(Is there a good reason not to provide for `make uninstall` besides
more workload? --I actually have no idea what it takes to do so!)
${prefix}/lib[64]
${prefix}/include
${prefix}/share
Do you create yourself a "hardcoded" list of files you need to remove?
Otherwise, it's a time consuming hunting of files here and there.
That I forgot to remove :D.
Won't existing files be overwritten by `make install` as root?
option
--with-static-proj4=ARG Compile with PROJ.4 statically (deprecated, use
--with-proj=ARG Compile with PROJ.x (ARG=yes or path)
available.
in GRASS.
Markus M
Thank you Markus, Nikos
* Nikos Alexandris <nik@nikosalexandris.net> [2020-02-04 16:51:33 +0100]:
Actually, I did remote the `share/proj` directory too before
re-installing PROJ.
Nikos
