My unsolved problem is that "v.distance -pa" returns for example thousands of
lines in the following format:
7839|16
7839|17
7839|22
7839|23
7839|24
Reading the main command in python is not the problem (although I am a bit
confused between grass.pipe, grass.feed, grass.read). Are there any examples
(scripts in grass trunk maybe?) to follow in order to split the output, keep
the second "column", sort and keep the maximum? Actually the "split" is what
worries me most. I 've been looking for quite some time to find something that
gives me a strait answer but no luck yet.
The idea is to feed later on v.what.vect with a "dmax=" as this seems to
reduce the eXtremely slow "v.distance" process as suggested by MoritzL in [1]
("v.distance" is running for 2 days here over large files[*]!).
I timed two different versions of v.what.vect (with and without "dmax=") and
it seems to make a difference (tested however in small spearfish vector data).
All this as part of a horrible script of mine [2]. I feel however that this
fits as an enhancement to "v.what.vect" itself.
Finding nearest lines...
Finding nearest areas...
404347 categories read from the map
404347 categories exist in the table
404347 categories read from the map exist in the table
404347 records updated
7839|16
7839|17
7839|22
7839|23
7839|24
there any examples
the output, keep
the "split" is what
find something that
that splits on ";" as the sep, and takes the first entry (column counting
starts at 0 not 1 here)
so for you: line.split('|')[1]
no idea about sorting, but you may be able to program a loop which
starts out empty and only updates if the line's dmax is bigger that the
one stored in the overall variable's, or if the variable is empty (for
the first).
For your task the use of lists and the split tool may help.
The different lines have are seperated by a '\n' (which is interpreted as a
new line). After splitting the string into a line list you can make a loop
each item of this list. Something like this:
a new line). After splitting the string into a line list you can make a
loop each item of this list. Something like this:
for line in line_list:
columns=line.split('|')
seccond_column_list.append(float(columns[1]))
max_value=max(seccond_column_list)
print seccond_column_list
print max_value
I may missunderstood your question but I hope this helps.
Thanks Hamish and Matthias.
Here one (more) solution:
# get distances from v.distance -pa
distances = grass.read_command("v.distance",\
flags = 'pa',\
_from = reference_points_map,\
to = lowres_vector_grid,\
column = gridcell_column,\
to_column = "cat",\
upload = "to_attr")
# get max distance
max_distance=max([float(d.split('|')[1]) for d in distances.splitlines()
[1:]])
(Thanks to Aggelos Nikolaou for the solution. It's something trivial but when
_not_ working all-the-time with python looks difficult in the beginning.)
