[GRASS-user] feedback on v.vect.stats
Hi Markus,
A short Feedback on the add-on "v.vect.stats" that you created.
Had an error saying "segmentation fault" for various reasons that were not precised any further:
Thought you might want to have a feedback eventually. I can't read "C"-lanuage and can't check the code. If this is the wrong place to give a feedback like this, please tell me where I should post this in future.
1.) columns "pcolumn, scolumn" are not created if not existing =>error is "segmentation fault"
2.) my "scolumn" was called "d_MEAN" in Postgresql. It seems postgresql does not recognize UPPER CASE. When I mentioned scolumn in the command with a upper case, error would be "typ must be double" instead of mentioning that the column was not existing
3.) pcolumn must be integer (not numeric). It will create error "segmentation fault" if not.
Then it worked great for points. (If you have a hint what approach I could take to perform the same analyses for lines that are completely in a polygon it would be great by the way).
greetz, Patrick
On Fri, Dec 10, 2010 at 5:36 PM, Patrick_schirmer <patrick_GIS@gmx.ch> wrote:
Hi Markus,
Thanks!
The mailing list is the right place.
I guess that is partially a typo on your side because pcolumn is never
created, it must exist because it is the column in the point vector
from which stats are collected. The segfault when creating ccolumn
and/or scolumn should be fixed as of r44583.
I tested only with dbf and sqlite, it's now working there. Could you
please test the fixed version with Postgresql backend? Thanks!
Should be fixed by now (r44583).
I was thinking about that too, extending it to collect stats on
points, lines or areas. That would be a bit of work, you could create
am enhancement ticket in trac as a reminder...
Markus M
