[GRASS-user] FFTW framework problem
Having had to rebuild a MacBook Pro, I've installed William K's 6.4.0RC5 build of Grass-GIS.
I'm running it under OS X 10.5.8.
Even though I have installed the FreeType framework (v2.3.11-1), ps.map crashes reporting a problem with the framework:
dyld: Library not loaded: /Library/Frameworks/FFTW3.framework/Versions/3/FFTW3
  Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gmath.dylib
  Reason: image not found
Trace/BPT trap
The first time it happened, I did the following:
- Delete the Grass-GIS application
- Trash the installer receipt
- Reinstall the framework
- Reinstall Grass-GIS and the Grass-GDAL plugin
The problem still occurs. Any suggestions?
Richard Chirgwin
The Leopard GRASS build still requires the FFTW framework, which is now in my download archives. The next version, whenever that happens, will be like the Snow Leopard build with an internal FFTW.
On Nov 3, 2009, at 2:48 PM, Richard Chirgwin wrote:
Trace/BPT trap
Richard Chirgwin
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
Many thanks! Fixed now.
Richard Chirgwin
Trace/BPT trap
Richard Chirgwin
