Hello,
I tried to import a 500 MB DEM using GRASS 6.2 (Debian rep):
#1
r.in.gdal -o -k -e
input=/data2/raster/dem/srtm90_africa_continental_JF/SRTM90_WA_v3/SRTM90_WA_v3/hdr.adf
output=test
Over-riding projection check.
Proceeding with import...
WARNING: map [test] - unable to write row 14319
File size limit exceeded
[Raster MASK present]
#2
did it without -e and previously zoomed into the mapset and set the region to
fit this extend using gis.m functionality (not CLI)
same error message
#3
I found related error messages in the ML hence I installed grass62 and 63 with
LFS but I have some problems compiling with gdal support (another e-mail on
gda-dev)
any idea how I can solve this file size limit problem while not yet being able
to compile 62/63?
regards, Martin
On Monday 13 November 2006 12:23, Martin Wegmann wrote:
Hello,
#1
r.in.gdal -o -k -e
_v3/hdr.adf output=test
#2
to fit this extend using gis.m functionality (not CLI)
same error message
#3
with LFS but I have some problems compiling with gdal support (another
e-mail on gda-dev)
just for the archive:
"libgdal.so.1" could not be found even though it was located using `locate
libgdal` but in /usr/local/lib
hence I added /usr/local/lib/ in
/etc/ld.so.conf and executed "ldconfig"
now import and LFS works.
Martin
able to compile 62/63?
regards, Martin
grassuser mailing list
grassuser@grass.itc.it
