given data in csv format with columns e.g. xcoor, ycoor and a few other as
input for v.in.ascii where some rows may have an empty entry in xcoor,
ycoor.
the idea for a little script wrapper for v.in.ascii:
filter the input file by empty xcoor, ycoor, then forward the
modified/filtered csv to v.in.ascii
On Tue, Jun 16, 2015 at 10:51 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
ycoor.
hellik@
> wrote:
hi,
as
ycoor.
Did you see the "new" flag of v.in.ascii
-i Ignore broken line(s) in points mode
? For us it did the job on a lot of data sets.
_-i Ignore broken line(s) in points mode_ doesn't work here.
it's GBIF data file (attached an short example: test.csv, and a modified one
by quoting the entries: test2.csv). GBIF data is"usually" in WGS84.
some xcoor, ycoor in this sample dataset are empty or where some xcoor,
ycoor have coordinates for some other coordinate systems not matching WGS84.
so some coordinate pairs are out of range for a ll-location.
Did you download from GBIF site? Because there are 2 (that I know) R packages that allows you to download data from GBIF, and you can ask for “NO SPATIAL ISSUES” in the data (among other options), probably in that way you can avoid these coordinates that are in a different reference system. Does that make sense?? Ah! The packages are: rgbif and dismo
If you want, I can provide an example… I just tried yesterday
HTH,
Vero
2015-06-27 10:16 GMT-03:00 Helmut Kudrnovsky <hellik@web.de>:
hellik@
> wrote:
hi,
as
ycoor.
Did you see the “new” flag of v.in.ascii
-i Ignore broken line(s) in points mode doesn’t work here.
it’s GBIF data file (attached an short example: test.csv, and a modified one
"NO SPATIAL ISSUES" in the data (among other options), probably in that
way
If you want, I can provide an example... I just tried yesterday
HTH,
Vero
thanks for the R hints, rgbif and dismo works quite nicely.
the addon imports downloaded and unzipped GBIF data via GDAL vector VRT to
the location without filtering non-existing/false latlong coordinates. these
points ca may be edited by the information given in the column locality
later on.
