[GRASS-user] find rivers, river paths, basin area, cumulative basin area along the path
Dear list,
I am interested in finding basin area limited to say 300sq km.
  1. Easier approach: is As suggested by Mr. M Metz earlier. It’s quite close.
Use SFD in r.watershed. Keep threshold in terms of number of cells equal to the area required. Use a raster dem 1 cells (r.grow) bigger than the basin boundary to get positive accumulation values.
Then run r.stream.extract. Keep threshold equal to the number used above.
Find starting points . Use layer 2 option and type_code=0.
These points are having the catchment equal to the threshold. (at least, as far as I have checked. I am still on job.)
The river starts forming when the given threshold is reached.
  1. Not so easy approach:
echo “delete from cat_temp_done;” > file.sql;
db.execute input=file.sql;
r.watershed -s --overwrite -m memory=12000 elevation=ybdem@PERMANENT threshold=12345 accumulation=step1_acc drainage=step1_fdir basin=step1_basin stream=step1_stream
r.stream.extract --overwrite memory=12000 elevation=ybdem@PERMANENT accumulation=step1_acc threshold=12345 stream_length=2 stream_rast=step1_stream_rse stream_vect=step1_stream_rse direction=step1_stream_fdir
v.db.addcolumn map=step1_stream_rse@PERMANENT layer=1 columns=“basin_area double precision,basin_area_point double precision”
v.db.addtable map=step1_stream_rse@PERMANENT layer=2
#find start points
v.extract -t --verbose input=step1_stream_rse@PERMANENT layer=2 type=point cats=0 output=zero_points_delete
v.category --overwrite --verbose input=zero_points_delete@PERMANENT output=zero_points_no_cat_delete option=del
v.category --overwrite --verbose input=zero_points_no_cat_delete@PERMANENT output=zero_points_with_cat_delete option=add
v.select --overwrite --verbose ainput=step1_stream_rse@PERMANENT alayer=1 atype=point binput=zero_points_with_cat_delete@PERMANENT blayer=1 btype=point output=zero_points@PERMANENT operator=equals
#find outlets
v.extract -t --verbose input=step1_stream_rse@PERMANENT layer=2 type=point cats=2 output=outlet_points_delete
v.category --overwrite --verbose input=outlet_points_delete@PERMANENT output=outlet_points_no_cat_delete option=del
v.category --overwrite --verbose input=outlet_points_no_cat_delete@PERMANENT output=outlet_points_with_cat_delete option=add
v.select --overwrite --verbose ainput=step1_stream_rse@PERMANENT alayer=1 atype=point binput=outlet_points_with_cat_delete@PERMANENT blayer=1 btype=point output=outlet_points@PERMANENT operator=equals
start_cats=echo "select cat from zero_points_step1_stream_rse;" | db.select -c;
end_cat=echo "select cat from outlet_points_step1_stream_rse;" | db.select -c;
for i in $start_cats
do
for j in $end_cat
do
echo “i:$i, j:$j”
v.net.salesman --overwrite input=step1_stream_rse@PERMANENT output=river_path_$i type=line alayer=1 nlayer=1 ccats=$i,$j
v.db.addtable map=river_path_$i@PERMANENT columns=“cat integer, basin_area double precision, basin_area_point double precision”
path_line_cats=echo "select cat from river_path_$i;" | db.select -c;
prev_area_value=0;
for x in $path_line_cats
do
echo “i:$i, j:$j, x: $x”
r.stream.basins dirs=step1_stream_fdir@PERMANENT streams=step1_stream_rse@PERMANENT cats=$x basins=river_path_basins_$i_$x
area_value=r.stats -a -n --verbose input=river_path_basins_$i_$x@PERMANENT | awk '{print $2}'
echo “Update river_path_$i set basin_area=$area_value where cat=$x;” > file.sql;
area_value_point=$area_value-$prev_area_value
echo “Update river_path_$i set basin_area_point=$area_value_point where cat=$x;” > file.sql;
$prev_area_value=$area_value
done
line_cats=echo "select cat from river_path_$i and cat not in (select cat from cat_temp_done);" | db.select -c;
for k in $line_cats
do
echo “i:$i, j:$j, x: $k”
r.stream.basins dirs=step1_stream_fdir@PERMANENT streams=step1_stream_rse@PERMANENT cats=$k basins=river_path_basins_$i_$k
area_value=r.stats -a -n --verbose input=river_path_basins_$i_$k@PERMANENT | awk '{print $2}'
echo “Update step1_stream_rse set basin_area=$area_value where cat=$k;” > file.sql;
echo “Update step1_stream_rse set basin_area_point=$area_value_point where cat=$k;” > file.sql;
echo “insert into gis_schema.cat_temp_done (cat) values($k);” > file.sql;
done
done
done
___________________________________________________________________________________________________–
The above codes will neatly arrange the required values in the columns. Which I shall later use on as label on points on river path.
  1. Not so easy – Not so easy approach
Replace the one line code of v.net.salesman used above with this:
elcat=1972;
echo “delete from work.cat_temp;” > file.sql;
echo “delete from work.cat_temp_done;” > file.sql;
echo “delete from work.yrse100sqkm_stream_path1;” > file.sql;
while [ “$elcat” ]
do
cats_to_write=echo "select cat from work.yrse100sqkm_stream where end_long=(select start_long from work.yrse100sqkm_stream where cat=$elcat) and end_lat=(select start_lat from work.yrse100sqkm_stream where cat=$elcat);" | db.select -c;
echo “delete from work.cat_temp where cat= $elcat;” > file.sql;
echo “cats_to_write: $cats_to_write”;
if [ ! -n “$cats_to_write” ]
then
echo “Update work.yrse100sqkm_stream set typecode=0 where cat=$elcat;” > file.sql;
else
echo “Update work.yrse100sqkm_stream set typecode=1 where cat=$elcat;” > file.sql;
for k in $cats_to_write
do
echo “insert into work.cat_temp (cat) values($k);” > file.sql;
prev_path=9999999;
prev_path=echo "select cat from work.yrse100sqkm_stream_path1 where path_cat=$elcat; " | db.select -c;
for p in $prev_path
do
echo “p:k: $p,$k”;
echo “insert into work.yrse100sqkm_stream_path1 (cat,path_cat) values($p,$k);” > file.sql;
done
echo “insert into work.yrse100sqkm_stream_path1 (cat,path_cat) values($elcat,$k);” > file.sql;
done
fi
elcat=echo "select cat from work.cat_temp limit 1;" | db.select -c;
done
or with this
elcat=1972;
while [ $elcat ]
do
cats=echo "select cat from work.yrse100sqkm_stream where end_long=(select start_long from work.yrse100sqkm_stream where cat=$elcat) and end_lat=(select start_lat from work.yrse100sqkm_stream where cat=$elcat) and cat <> $elcat; " | db.select -c;
if [ ! -n “$cats” ]
then
echo “insert into work.river_startline(cat) values($elcat);” > file.sql;
fi
echo “insert into work.cat_temp_done (cat) values($elcat);” > file.sql;
cats_to_write=echo "select cat from work.yrse100sqkm_stream where end_long=(select start_long from work.yrse100sqkm_stream where cat=$elcat) and end_lat=(select start_lat from work.yrse100sqkm_stream where cat=$elcat) and cat not in (select cat from work.cat_temp_done); " | db.select -c;
do
done
done
and then
echo “delete from yrse100sqkm_stream_path;” > file.sql;
elcats=echo "select cat from work.river_startline;" | db.select -c;
for i in $elcats
do
cats=$i
declare -i order;
order=1;
while [ $cats ]
do
echo “insert into work.yrse100sqkm_stream_path (cat,path_cat,orderno) values($cats,$i,$order);” > file.sql;
echo “cat: $cats,path: $i,order: $order”;
cats=echo "select cat from work.yrse100sqkm_stream where start_long=(select end_long from work.yrse100sqkm_stream where cat=$cats) and start_lat=(select end_lat from work.yrse100sqkm_stream where cat=$cats) limit 1; " | db.select -c;
order=order+1;
done
done
Definitely, knowledge of python would have made things easier.
Thanks to all for the help.
