[GRASS-user] Finding why postgres database cannot be opened
   Grass seems to recognize the postgres data base and that I'm logged in to
it:
db.connect -p
driver: pg
database: /home/rshepard/data/grassdata/willamette_basin/willamette-river-hg
db.login driver=pg database=willamette-river-hg --o
WARNING: DB connection <pg/willamette-river-hg> already exists and will be
          overwritten
   If the mapset recognizes that geometry attributes are stored in the
postgres database, and user me has access to these attribute tables, what
might be the cause of this error (seen with multiple maps):
db.columns table=fishes
DBMI-PostgreSQL driver error:
Connection failed.
FATAL: database "/home/rshepard/data/grassdata/willamette_basin/willamette-river" does not exist
WARNING: Unable to open database
          </home/rshepard/data/grassdata/willamette_basin/willamette-river-hg>
          by driver <pg>
Connection failed.
TIA,
Rich
Hi Rich,
it:
db.connect -p
driver: pg
overwritten
Connection failed.
by driver <pg>
Connection failed.
I think you need to slow down a bit and try to review your basic understanding of things (maybe [1] could do with a bit more substance).
You are trying to connect to a database that is called "/home/rshepard/data/grassdata/willamette_basin/willamette-river-hg", not (as it should be) "willamette-river-hg".
Also, as MarkusM has already mentioned:
- db.connect does not test for the existence of the database. It just sets the content of the file definining the default mapset connection and outputs the content of this file. Use db.test to test your connection.
- The same goes for db.login: it just writes out the login info into a file. AFAIR, it is not absolutely necessary to use db.login to be able to connect to a database, especially if you do not need a password for connection.
- If you want to check the database connection of a specific vector map, please use v.db.connect -p.
Moritz
[1] https://grass.osgeo.org/grass74/manuals/databaseintro.html
Moritz,
   I do need to step back a bit.
   Yes, I see where I kept confusing path names for the sqlite and postgres
tables.
   Almost all issues are now resolved, but I need to add a 'cat' column to
the postgres stations table (it has more columns than does the sqlite one),
so I'll so this with psql and insert sequential numbers in that column that
follow the site_nbr columns. Looking at all tables, I think this is the last
hurdle to displaying the stations table.
   Thanks very much.
Rich
On Wed, Nov 7, 2018 at 8:40 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Moritz,
“/home/rshepard/data/grassdata/willamette_basin/willamette-river-hg”, not (as
it should be) “willamette-river-hg”.
tables.
Almost all issues are now resolved, but I need to add a ‘cat’ column to
so I’ll so this with psql and insert sequential numbers in that column that
I am afraid that manually adding a cat column and populating it with sequential numbers will not work: how do you assure that the cat numbers and corresponding attribute values indeed correspond to the cat values of the vector features? Chances are high that vector features get linked to wrong attributes.
Considering all the modifications that you have done in the meantime I suggest to start from scratch:
  1. decide on the default database connection you want to use
  2. set up the default database connection if not sqlite
  3. test the database connection e.g. with db.tables
  4. create vector maps
Markus M
Thanks very much.
Rich
grass-user mailing list
grass-user@lists.osgeo.org
wrong attributes.
Markus M,
   Grass told me the stations table has no categories, which it does not
because the map's attribute table was derived from the pre-existing postgres
database table and the geometry created by the easting/northing pairs in
that table.
   The other maps and tables were created from agency-sourced GIS
repositories and grass created cat columns for them, so it's only the
stations table needing that column to be added.
db.select sql="select * from stations limit 3"
site_nbr|site_name|lon|lat|easting|northing|start_date|end_date|howmany|bin_col|cat
10332|Willamette R. at SP&S RR Bridge (Portland)|-122.7475|45.577944|||1979-11-06|2003-06-19|25|231:00:231|
10917|Pudding R. at Hwy 99E (Aurora)|-122.748972|45.233806|||1979-11-06|2008-03-26|22|231:00:231|
10376|McKenzie R. at Coburg Road|-123.046194|44.112722|||1980-05-07|2011-01-04|40|231:173:00|
   No cat values there now. But, updating the table and setting a distinct cat
number for each site_nbr will fill that column.
Rich
   The issues with specifying database paths and needing a filled cat column
in the stations table have been resolved. v.db.connect shows a valid
connection to the database table:
v.db.connect map=stations -p
Vector map <stations> is connected by:
layer <1/stations> table <stations> in database
</home/rshepard/data/grassdata/willamette_basin/willamette-river-hg> through
driver <pg> with key <cat>
but, trying to display that map using v.colors in a script still fails to
find the database:
$HOME/documents/white-papers/geochemistry/willamette-river-mercury/scripts/grass-display-sample-sites.sh
d.vect complete.
Connection failed.
          by driver <pg>
ERROR: Unable to open database
        by driver <pg>
   The script:
#!/usr/bin/bash
db.connect driver=pg database=willamette-river-hg
g.region vect=wrb
d.mon start=wx0
d.vect map=wrb col=black fill_col=none
d.vect map=wrb_rivers col=blue fill_col=blue
v.colors map=stations use=attr column=howmany rules=rules.txt rgb_col=bin_col --o
and the color rules file:
1 231:00:00
10 231:00:00
11 89:00:00
20 89:00:00
21 231:00:231
30 231:00:231
31 231:173:00
40 231:173:00
41 231:115:00
50 231:115:00
51 00:231:57
60 00:231:57
61 115:231:00
70 115:231:00
TIA,
Rich
Hi Rich,
if you use a postgres database (driver=pg) you have to specify the full connection string to the database. You can see this in the manual for db.connect (look for PostgreSQL):
db.connect driver=pg database="host=myserver.itc.it,dbname=mydb"
I.e. if the db is on your local machine the host is your IP adress or "localhost":
db.connect driver=pg database="host=localhost,dbname=willamette-river-hg"
If you use a Sqlite database you can omit driver specification, because that is the default.
regards.
Stefan
Rich Shepard <rshepard@appl-ecosys.com> hat am 7. November 2018 um 23:44 geschrieben:
find the database:
d.vect complete.
d.vect complete.
Connection failed.
          by driver <pg>
        by driver <pg>
   The script:
#!/usr/bin/bash
g.region vect=wrb
d.mon start=wx0
1 231:00:00
10 231:00:00
11 89:00:00
20 89:00:00
21 231:00:231
30 231:00:231
31 231:173:00
40 231:173:00
41 231:115:00
50 231:115:00
51 00:231:57
60 00:231:57
61 115:231:00
70 115:231:00
TIA,
Rich
On Wed, Nov 7, 2018 at 11:45 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
It’s not resolved, and it is not a valid connection:
Vector map is connected by:
layer <1/stations> table in database
driver with key
for driver=pg, the database must not be a path, it must be database=willamette-river-hg
Also, be aware of the differences between db.connect and v.db.connect. The pg database willamette-river-hg must have been established first with db.connect + db.login, only after that you can use v.db.connect which is not needed for newly created vectors.
Markus M
find the database:
d.vect complete.
d.vect complete.
Connection failed.
FATAL: database “/home/rshepard/data/grassdata/willamette_basin/willamette-river” does not exist
by driver
by driver
The script:
#!/usr/bin/bash
g.region vect=wrb
d.mon start=wx0
1 231:00:00
10 231:00:00
11 89:00:00
20 89:00:00
21 231:00:231
30 231:00:231
31 231:173:00
40 231:173:00
41 231:115:00
50 231:115:00
51 00:231:57
60 00:231:57
61 115:231:00
70 115:231:00
TIA,
Rich
On Thu, 8 Nov 2018, Markus Metz wrote:
It's not resolved, and it is not a valid connection:
through
Markus M.
   I now understand the differences between db.connect and v.db.connnect and
did not recognize the full path returend by v.db.connect.
   Each time I run db.connect -p it shows the postgres database and the pg
driver. When I saw the results of v.db.connect I added this line to the top
of the script
(I did not re-login because that always returned the message that I had been
logged in so the command overwrote the existing login with a new one.)
   Re-running the script produced the same error.
   If db.connect returns the proper database name (without the full path),
while v.db.connect has the full path, how do I correct this? I've looked at
db.* and v.db.* and not seen what I should do to have the v.db.connect see
the database without a path.
Rich
Stefan,
   Each time I think that I have the path requirement differences between
db.connect and v.db.connect understood there's aninstance when I mix them up
unintentionally. I've changed the db.connect line in the script to use
localhost rather than the absolute path.
   As I responded to Markus M, I don't know how to fix the absolute path
returned by v.db.connect
db.connect -p
driver: pg
database: host=localhost,dbname=willamette-river-hg
schema: group:
v.db.connect -p map=stations
   Trying again:
db.connect driver=pg database=$HOME/data/grassdata/willamette_basin/willamette-river-hg
   What am I still doing incorrectly with db.connect?
Rich
Hi Rich,
to connect the database tabel to your map you have to specify the postgres connection with v.db.connect as well:
v.db.connect map=stations driver=pg database="host=localhost,dbname=willamette-river-hg" table=<NameOfTheTable> key=<NameOfTheCatColumn>
Consider that the <NameOfTheTable> have to be different from the name of the mapset, i.e. must not be called "stations"!
Regards.
Stefan
Rich Shepard <rshepard@appl-ecosys.com> hat am 8. November 2018 um 15:07 geschrieben:
Stefan,
> db.connect -p
driver: pg
schema:
group:
   Trying again:
Rich
   Fixed: it's not db.connect, it was not providing all fields to the
v.db.connect command:
v.db.connect map=stations driver=pg database=willamette-river-hg \
table=stations layer=1 sep=pipe -o
The table <stations> is now part of vector map <stations> and may be
deleted or overwritten by GRASS modules
layer <1/stations> table <stations> in database <willamette-river-hg>
through driver <pg> with key <cat>
   Thank you Markus M and Stefan.
Rich
