Everything goes alright until "Start GRASS" then I get this error:
"g.proj or projection error: dyld: Library not loaded:
/Library/Frameworks/PROJ.framework/Versions/4.6/PROJ Referenced from
/Applications/GRASS-6.4.app/Contents/MacOS/bin/g.proj Reason: image
not found" and crash. Any ideas?
error:
Referenced from
Reason: image not found" and crash. Any ideas?
did you install all the required framework packages listed on
the Mac download site?
