[GRASS-user] First time trying to install add on g.extension (r.stream.order)
David wrote:
Using GRASS 6.4.0 on windows vista I type "g.extension
extension=r.stream.order" in the command line at the bottom of
the layer manager window. The following error is returned:
"Error: svn client required. Please install Subversion first."
I have looked through many posts and help files to no avail, if
anyone can tell me what additional steps/programs/plugins are
required to install addons I would really appreciate the help.
see http://subversion.apache.org
note g.extension is rather new and untested compared the rest of
the software, especially on Windows. Besides svn for building C
modules, you will need a C compiler which doesn't ship with the
GRASS installer.
Hamish
GRASS installer.
What about a automtaci build process on the server?
Then the users would download a "package" and drop in a extension
directory or use g.extension for that task.
I mean something similar to Launchpad PPA or PyPi.
On Sat, Sep 25, 2010 at 10:47 AM, Tim Michelsen
GRASS installer.
For Windows:
We need to convince Martin Landa to run a compilation of all
Addons on his winGRASS build server. I have added Makefiles
to most directories, whatever is missing would just be not there then.
Then copy the resulting *.exe into a separate Addons download directory
on josef...
