[GRASS-user] Fixing Collared DRGs
Hi folks-
I’m new to GRASS, but am eager to learn a GIS that doesn’t require me to use Windows. I can manage to do the basics with GRASS (although I’m having trouble with the python GUI, but that’s another story). What I’m trying to do now is remove white collars from some GeoTiff topo maps I got for an area in Montana (my region of interest overlaps the corners of four quadrangles). These have white borders, and the border region is the same white as the white of the map itself (color index 1). When I downloaded the maps, there was a link to some scripts (for ArcMap) to remove the collars, and I imagine that there is some equivalent way to do it for GRASS.
I’m running GRASS 6.3.0RC5 (using the X11 tcltk interface) on a PowerMac G4.
Dave
On Mon, Mar 31, 2008 at 03:00:41PM -0700, we recorded a bogon-computron collision of the <dhirsch226@gmail.com> flavor, containing:
Hi folks- I'm new to GRASS, but am eager to learn a GIS that doesn't require
me to use Windows. I can manage to do the basics with GRASS (although I'm
having trouble with the python GUI, but that's another story). What I'm
I'm running GRASS 6.3.0RC5 (using the X11 tcltk interface) on a PowerMac G4.
It is a little tedious but not especially difficult, and easily scripted.
Here's how I do it:
Go to www.geocomm.com and download their 24kgrid.shp "quad index" file. It
contains the lat/lon rectangles for all the USGS 7.5' DRGs in the whole US.
Extract the set of outlines for your state to a shapefile:
  ogr2ogr -where "STATE='MT'" montana_quads.shp 24kgrid.shp
Now you need to translate those outlines to the UTM zone and datum that your
maps are in. Some states use quad maps all in NAD27, some have a mixture of
NAD83 and NAD27 maps. The 24kgrid shapefile has no associated .prj file,
and just contains the lat/lon boundaries of the quads (inside the neatlines).
If your GRASS location is UTM zone 12, NAD27 (and your DRGs are also NAD27,
UTM zone 12), you could do this:
  ogr2ogr -t_srs EPSG:26712 -s_srs EPSG:4267 montana_quads_UTM12_NAD27.shp montana_quads.shp
This reprojects the (assumed) NAD27 lat/lon rectangles into UTM Zone 12/NAD27
polygons. These will be used to clip the collars off of DRGs.
Then import this shapefile into your GRASS location with v.in.ogr:
  v.in.ogr dsn=montana_quads_UTM12_NAD27.shp output=quads27
Once you've done that, you're ready to collar-clip all the NAD27 DRGs you want.
Say you have a quad for Abbot Lake, MT that's called o48112d2.tif. You could
then do this:
  r.in.gdal input=o48112d2.tif output=o48112d2_withcollar
  v.extract where="MRC='48112-D2'" input=quads27 output=o48112d2_bounds
     (this selects only the single quad outline applicable)
  g.region rast=o48112d2_withcollar # this just to set resolution properly
  g.region vect=o48112d2_bounds # to set the region only to neatline
  v.to.rast input=o48112d2_bounds output=o48112d2_bounds use=val value=1
     (this one generates a raster that's 1 inside the neatline, null outside)
  echo "o48112d2_withoutcollar=if(!isnull(o48112d2_bounds),o48112d2_withcollar,null())" | r.mapcalc
    (this populates the _withoutcollar map only where the mask is non-null)
    (you could also do it with
        r.mask input=o48112d2_bounds
        echo "o48112d2_withoutcollar=o48112d2_withcollar"| r.mapcalc
        r.mask -r
  r.colors map=o48112d2_withoutcollar rast=o48112d2_withcollar
    (to copy colormap from original)
If the location is in a different datum than the DRG, I add a couple steps. For
example, if my location is in NAD27 and the DRG is in NAD83, I'd do this:
  ogr2ogr -t_srs EPSG:26712 -s_srs EPSG:4269 montana_quads_UTM12_NAD83.shp montana_quads.shp
this creates a NAD27/UTM Zone 12 shapefile of the outlines of NAD83 quad maps.
I'd then import this as, say, "quads83" with v.in.ogr, and the steps would be:
  gdalwarp -t_srs EPSG:26712 o48112d2.tif o48112d2_NAD27.tif
  r.in.gdal input=o48112d2_NAD27.tif output=o48112d2_withcollar
  v.extract where="MRC='48112-D2'" input=quads83 output=o48112d2_bounds
ull())" | r.mapcalc
        r.mask -r
Only the first three steps are different.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
one trick, rational thinking, but when you're good and crazy, oooh, oooh,
oooh, the sky is the limit!" --- The Tick
outside)
  echo
| r.mapcalc
non-null)
        r.mask -r
Hi
Another way is to use gdal_rasterize. See point e) under the Mosaicing
section of this tutorial by Frank Warmerdam:
http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial
Craig
View this message in context: http://www.nabble.com/Fixing-Collared-DRGs-tp16410116p16450018.html
On Wed, Apr 02, 2008 at 12:51:35PM -0700, we recorded a bogon-computron collision of the <Craig@pid.co.za> flavor, containing:
> outside)
> echo
> | r.mapcalc
> non-null)
> r.mask -r
Hi
Neat. The same 24kgrid shapefile could be the source of the vector clipping
region for that technique, too. Thanks for pointing that out, I hardly
ever use gdal_rasterize and didn't know it could do that.
