I notice with a floating point raster that there appears to be a numbering
problem in the histogram's x-axis.
All values in the file are are from zero to 159, no negative values.
Horizontally expanding the histogram is not helpful re the x values. Please
see attached file.
Could Gnuplot be a convenient workaround - if you could point me to any up
to date and relevant literature?
On Fri, Dec 28, 2012 at 6:39 AM, RichardC <richtcooper@hotmail.com> wrote:
see attached file.
Yes, the d.histogram ticks calculation is far from satisfying.
(see below)
Gnuplot may be a way, see i.spectral for a usage (it is a script).
