[GRASS-user] Flow direction to flow accumulation
Hello all,
Does GRASS have a tool equivalent to what ArcGIS calls Flow Accumulation? Input is a flow direction raster and output is a cumulative catchment area raster. As an optional argument you can specify a weight raster, which is really important for what I am trying to do - count cells of woodland upstream from each cell in the flow direction grid.
All GRASS tools I thought could do this require DTM as input, not flow direction raster, and they also don’t allow to specify the weight raster. As far as I can see.
Do you know about any other OSGeo tools that could do this? Ideally Python friendly?
Best regards,
Filip Kral.
Filip,
Yes; look at the GRASS raster commands: r.terraflow, r.watershed
Tom
On Thu, Nov 19, 2015 at 5:02 PM, wcd <vydramail@quick.cz> wrote:
Hello all,
Best regards,
Filip Kral.
grass-user mailing list
grass-user@lists.osgeo.org
Thomas E Adams, III
2330 Jack Warner PKWY, #334
Tuscaloosa, AL 35401
1 (513) 739-9512 (cell)
As far as I can see, you have one option: r.drain creates drainage lines based on a flow direction grid and and input grid (“weight” raster). With the “-a” flag the total weights are placed into the output cells. But this module gives you accumulation only along the drainage lines, NOT a full flow accumulation grid.
On 11/20/2015 01:02 AM, wcd wrote:
Hello all,
Best regards,
Filip Kral.
This mail was received via Mail-SeCure System.
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Arava Drainage Authority
+972-523-665918
